查看: 982|回复: 2
[提问] 能改为合拼后,上下,左右,都对中(居中)吗
发表于 2019-12-8 00:36:04 | 显示全部楼层 |阅读模式
3明经币
;;;*****文字合并 程序开始*****
(defun c:hbh (/ lst)
  (setq oldaun (getvar "aunits"))
  (setvar "aunits" 3)
  (setvar "osmode" 15359)
  (setvar "cmdecho" 0)
  (command "undo" "be")
  (princ "\n★功能:文字合并。\n \n")
  (setq ss (ssget '((0 . "MTEXT,TEXT"))))
  (setvar "osmode" 0)
  (initget "E S A")
  (if (not (setq kword
                  (getkword
                    "\n在合并文字之间加:[换行(E)/空格(S)/直接合并(A)]<E>"
    (setq kword "E")
  (setvar "osmode" 0)
  (setq lst '())
  (while (> (sslength ss) 0)
    (setq entnam (ssname ss 0)
          entdat (entget entnam)
    (setq pt  (cdr (assoc 10 entdat))        ;读取文字的插入点坐标
          txt (cdr (assoc 1 entdat))        ;读取文字内容
          zg  (cdr (assoc 40 entdat))        ;读取文字的字高
          lst (cons (list pt txt zg) lst) ;将点坐标、内容、字高组成表
          ss  (ssdel entnam ss)                ;选择集中删除当前的文字对象
    (entdel entnam)                        ;删除文字对象
  (setq
    lst
     (vl-sort lst
(function
                (lambda        (e1 e2)
                  (if (equal (cadr (car e1)) (cadr (car e2)) 1e-4)
                    (> (car (car e1)) (car (car e2)))
                    (< (cadr (car e1)) (cadr (car e2)))
  (setq str "")
  (cond        ((= kword "S")
         (foreach e lst
           (setq str (strcat (cadr e) " " str))
        ((= kword "E")
         (foreach e lst
           (setq str (strcat (cadr e) "\n" str))
        ((= kword "A")
         (foreach e lst
           (setq str (strcat (cadr e) str))
  (command "MTEXT" pt "H" zg "W" 0 str "")
  (princ "\n★提示:文字合并完成.\n")
  (setvar "aunits" oldaun)
  (command "undo" "e")
;;;*****文字合并 程序结束****
附件: 您需要 登录 才可以下载或查看,没有账号?注册
最佳答案
发表于 2019-12-8 00:36:05 | 显示全部楼层
  1. ;;;*****文字合并 程序开始*****
  2. (defun c:hbh (/ lst)
  3. (setq oldaun (getvar "aunits"))
  4. (setvar "aunits" 3)
  5. (setvar "osmode" 15359)
  6. (setvar "cmdecho" 0)
  7. (command "undo" "be")
  8. (princ "\n★功能:文字合并。\n \n")
  9. (setq ss (ssget '((0 . "MTEXT,TEXT"))))
  10. (setvar "osmode" 0)
  11. (initget "E S A")
  12. (if (not (setq kword (getkword "\n在合并文字之间加:[换行(E)/空格(S)/直接合并(A)]<E>")))
  13.   (setq kword "E")
  14. )
  15. (setq lst '())
  16. (while (> (sslength ss) 0)
  17.   (setq entnam (ssname ss 0)
  18.        entdat (entget entnam)
  19.   )
  20.   (setq pt (cdr (assoc 10 entdat)) ;读取文字的插入点坐标
  21.        txt (cdr (assoc 1 entdat)) ;读取文字内容
  22.        zg (cdr (assoc 40 entdat)) ;读取文字的字高
  23.        lst (cons (list pt txt zg) lst) ;将点坐标、内容、字高组成表
  24.        ss (ssdel entnam ss) ;选择集中删除当前的文字对象
  25.   )
  26.   (entdel entnam) ;删除文字对象
  27. )
  28. (setq lst
  29.   (vl-sort lst
  30.    (function
  31.     (lambda (e1 e2)
  32.      (if (equal (cadar e1) (cadar e2) 1e-4) ;Y坐标
  33.       (> (caar e1) (caar e2)) ;X坐标
  34.       (< (cadar e1) (cadar e2)) ;Y坐标
  35.      )
  36.     )
  37.    )
  38.   )
  39. )
  40. (setq str "")
  41. (cond
  42.   ((= kword "S")
  43.    (foreach e lst (setq str (strcat (cadr e) " " str)))
  44.   )
  45.   ((= kword "E")
  46.    (foreach e lst (setq str (strcat (cadr e) "\n" str)))
  47.   )
  48.   ((= kword "A")
  49.    (foreach e lst (setq str (strcat (cadr e) str)))
  50.   )
  51. )
  52. (command "MTEXT" pt "H" zg "J" "MC" "W" 0 str "")
  53. (princ "\n★提示:文字合并完成.\n")
  54. (setvar "aunits" oldaun)
  55. (command "undo" "e")
  56. (setvar "osmode" 15359)
  57. (princ)
  58. )
  59. ;;;*****文字合并 程序结束****
 楼主| 发表于 2019-12-9 11:31:15 | 显示全部楼层
谢谢,感激.....................
GMT+8, 2025-5-18 11:11 , Processed in 0.179733 second(s), 25 queries , Gzip On.
