查看: 1222|回复: 3
[源码] 快捷填充的LSP----为什么填充完后捕捉点就消失了?
发表于 2019-12-11 15:49:10 | 显示全部楼层 |阅读模式
请问各位坛友哪儿有毛病呢?
(defun C:Hsd (/ s1 s2)
  (setvar "cmdecho" 0)
  (setvar "OSMODE" 0)
  (setvar "MEASUREINIT" 1)
  (setvar "MEASUREMENT" 1)
  (setvar "hpassoc" 1)   ;控制填充图案是否关联(1:是;0:否)
  (princ
    "\n快捷填充,请选择填充区域:(***跳过则为拾取内部点填充)"
  (if (setq s1 (ssget))
    (command "layer"  "m"      "ht"
      "c"  "8"      ""   "lw"
      "1"  ""      "l"  "Continuous"
      ""   ""      "_.bhatch"  "p"
      "AR-SAND,_o"  "10"      "0"  "s"
      s1          ""      ""
      (princ "\n请拾取填充内部点:")
          (IF (vl-cmdf "layer"  "m"      "ht"
      "c"  "8"      ""   "lw"
             "_.bhatch" (getpoint) "p"  "AR-SAND,_o" "10" "0" "")
     (princ "\n请选择填充...")
发表于 2019-12-11 18:27:37 | 显示全部楼层
(setvar "OSMODE" 0)
发表于 2019-12-11 18:28:00 | 显示全部楼层
你设置了取消捕捉,没有恢复
 楼主| 发表于 2019-12-11 22:22:37 | 显示全部楼层
(command "OSNAP" "ENDPOINT,MIDPOINT,CENTER,NODE,QUADRANT,NEAREST,intersection,perpendicular" ) 我加了这个就可以了。谢谢
GMT+8, 2025-5-18 11:48 , Processed in 0.167409 second(s), 25 queries , Gzip On.
