查看: 11065|回复: 34
[讨论] 关于画垂线的,哪位大佬给优化一下啊,拜托了
发表于 2019-12-17 14:03:51 | 显示全部楼层 |阅读模式
5明经币
以下代码是两个命令,一个是画垂线的,一个是画中垂线的,最理想的是把两个命令合成一个,留个选项可以键值切换,默认垂线,能识别普通直线,构造线,块中的直线,多段线,尺寸线
运行时,普通垂线时先选择直线,然后提示垂足通过的点,中垂线时输入键值直接出结果
垂线的长度,可以用xline也可以是线,长度放的长点就行,100000就够了,默认当前图层,这些就够了,谢谢!!!
(defun c:cx()
(setvar "CMDECHO" 0)
(if (setq s1 (entsel "\n選取直線:")) (progn
  (setq pt (cadr s1)
        pt2 (osnap pt "NEAR")
        pt1 (polar pt2 (angle pt2 pt) 900)
        pt3 (polar pt2 (angle pt pt2) 900)
        pt4 (polar pt1 (angle pt pt2) -150)
        pt5 (polar pt3 (angle pt2 pt) -150))
   (command "PLINE" pt4  pt1 pt3 pt5 "")
(setvar "CMDECHO" 1)
(defun C:ZC (/ ENT P1 P2 MP AN DI)
  (setq ENT (entsel "\n選取直線:")
        ENT (entget (car ENT))
        P1  (cdr (assoc 10 ENT))
        P2  (cdr (assoc 11 ENT))
        MP  (mapcar '(lambda (X Y) (/ (+ X Y) 2.)) P1 P2)
        AN  (+ (angle P1 P2) (/ PI 2.))
        DI  (/ (distance P1 P2) 2.)
  (entmake (list '(0 . "LINE")
                 (cons 10 (polar MP AN DI))
                 (cons 11 (polar MP AN (- DI)))
最佳答案
查看完整内容
;;;师兄QQ361865648 ;;;好人做到底,送佛送到西,好吧,现在块可以使用了,尺寸也可以了,不过要多响应一次;;再要如何你自已弄了,浪费我太多时间,应该是你要的效果了 (vl-load-com) (defun cxfun (ent / ename pickpt ponl ang p1 p2 entdat etype pt) (setq ename (car ent)) (setq entdat(entget ename) etype(cdr(assoc 0 entdat))) (setq pickpt (cadr ent)) (cond ( (member etype '("CI ...
发表于 2019-12-17 14:03:52 | 显示全部楼层
;;;师兄QQ361865648
(vl-load-com)
  (cond
    (  (member etype
               '("CIRCLE" "ELLIPSE" "RAY" "LINE" "XLINE" "SPLINE"
                 "LWPOLYLINE")
    (setq ponl (vlax-curve-getClosestPointTo ename pickpt))
    (t (setq ponl (osnap pickpt "_nea"))))
  (setq ang (angle pickpt ponl))
  (setq pt(VL-CATCH-ALL-APPLY 'getpoint (list "\n指定垂足点: ")))
  (if (and pt (not (VL-CATCH-ALL-ERROR-P pt)))
    (setq p1(polar pt ang 1000)
          p2(polar pt (+ ang pi) 1000))
  (setq        p1 (polar ponl ang 1000)
        p2 (polar ponl (+ ang PI) 1000)
                 (cons 10 p1)
                 (cons 11 p2)
(defun c:cx (/ ent)
  (setq ent (entsel "\n選取直線:"))
  (vl-CATCH-ALL-APPLY 'cxfun '(ent))
(defun ZCfun (ent / ename pickpt ponl ang p1 p2 entdat etype)
  (cond
    (  (member etype
                 "LWPOLYLINE")
  (setq midp (osnap ponl "_mid")) ;_中点
  (setq        p1 (polar midp ang  1000)
        p2 (polar midp (+ ang PI)  1000)
                 (cons 10 p1)
                 (cons 11 p2)
(defun c:ZC (/ ent)
  (vl-CATCH-ALL-APPLY 'Zcfun '(ent))
(defun c:test (/ mystr k str mod ent mod)
  (setq        mystr (list "中垂线" "一般垂线")
        k     0
        str   (nth k mystr)
        mod   t
  (while mod
    (setq ENT (VL-CATCH-ALL-APPLY
                'entsel
                (list (strcat "\n選取直線 <" str "> :"))
    (if
      (not (VL-CATCH-ALL-ERROR-P ent))
       (cond
         ((null ent) (setq k (- 1 k)))
          (t
            (if        (= k 0)
              (VL-CATCH-ALL-APPLY 'ZCfun (list ent))
              (VL-CATCH-ALL-APPLY 'cxfun (list ent))
         (setq mod nil)
       (setq str (nth k mystr))
xj6019 + 1 淡定
发表于 2019-12-17 22:03:39 | 显示全部楼层
;;;师兄QQ361865648,用A键切换中垂线和一般垂线
(defun c:ts1 (/             ang    endpt  entdat entpick        ept    etype
              inpt   intpt  len           midp          midpt         mode        ospts  p1
              p2     pt            ret           sortlst         startpt       x
              y
  (while (and (setq entpick (entsel "\n選取直線 :"))
              (setq entdat (entget (car entpick)))
              (setq etype (cdr (assoc 0 entdat)))
              (= etype "LINE")
    (setq startpt (cdr (assoc 10 entdat))
          endpt          (cdr (assoc 11 entdat))
          midpt          (getmidpt startpt endpt)
          len          (DISTANCE startpt endpt)
          ang          (angle startpt endpt)
          mode          nil
    (while (and
             (setq ret (grread t 12))
             (member (car ret) '(2 5))
      (redraw)
      (cond
        ((= (car ret) 2) (setq mode (not mode)))
        ((= (car ret) 5)
         (setq pt (cadr ret))
         (setq intpt (getprep startpt endpt pt))
         ;;如果离中点很近则自动为中垂线
;;;      (if (< (DISTANCE intpt midpt) (* 0.01 len))
;;;        (setq intpt midpt))
         (if mode
             (setq midp (osnap intpt "_mid"))
             (setq inpt (osnap intpt "_int"))
             (setq ept (osnap intpt "_end"))
             (setq ospts nil)
             (if midp
               (setq ospts (cons midp ospts))
             (if inpt
               (setq ospts (cons inpt ospts))
             (if ept
               (setq ospts (cons ept ospts))
             (setq sortlst nil)
             (if ospts
               (setq sortlst
                      (vl-sort ospts
                               '(lambda        (x y)
                                  (<= (DISTANCE x intpt) (DISTANCE y intpt))
             (if sortlst
               (setq intpt (car sortlst))
      (setq p1 (polar intpt (+ ang (* 0.5 PI)) (* 0.5 len))
            p2 (polar intpt (- ang (* 0.5 pi)) (* 0.5 len))
      (grdraw p1 p2 3)
    (redraw)
    (if        (= (car ret) 3)
                     (cons 10 P1)
                     (cons 11 P2)
参与人数 2明经币 +2 收起 理由
wowan1314 + 1 很给力!
xj6019 + 1 赞一个!
 楼主| 发表于 2019-12-17 22:45:52 | 显示全部楼层
(defun c:ts1 (/             ang    endpt  entdat entpick        ept  ...
您好老师,首先谢谢您的热心解答,您的想法虽然很新颖,但是与我的本意还是差了点
1,垂线生成预览后无法捕捉,虽然可以自由移动,但是有点过于自由了,想要放到某一个点还得手动移动一下,希望可以完善。
2.最最最重要的,我经常需要对构造线,多段线,尺寸线,图块里面的某根线做垂线,目前您的代码还是不行,这次求助主要想解决这个问题,如果不是解决这个问题,对普通直线,之前那代码是完全够我用的。
再次麻烦一下呗,把您的代码可否完善一下呀,谢谢!!
发表于 2019-12-18 00:54:59 | 显示全部楼层
  1. (defun c:cx ()
  2. (setq ukw (Ukword 1 "1 2" "1-垂线/2-中垂线" ukw))
  3.   (while (setq s1 (entsel "\n选线: "))
  4.     (setq pt (cadr s1)
  5.           p2 (osnap pt "near")
  6.           rr (angle pt p2)
  7.           p2 (if (= ukw "1") p2 (osnap pt "mid"))
  8.           p1 (polar p2 rr 1000)
  9.           p3 (polar p2 rr -1000)
  10.     )
  11.     (command "line" "non" p1 "non" p3 "")
  12.   )
  13.   (princ)
  14. )
  1. (defun ukword (bit kwd msg def / inp)  (if (and def (/= def ""))
  2.     (setq msg (strcat "\n" msg "<" def ">: ")
  3.           bit (* 2 (fix (/ bit 2)))
  4.     )
  5.     (setq msg (strcat "\n" msg ": "))
  6.   )
  7.   (initget bit kwd)
  8.   (setq inp (getkword msg))
  9.   (if inp inp def)
  10. )
发表于 2019-12-18 07:36:36 | 显示全部楼层
抽空给你看看吧,我那个能捕捉的,只是你没有试
发表于 2019-12-18 07:37:43 | 显示全部楼层
1,垂线生成预览后无 ...
抽空给你看看,我那个能捕捉,你没有试一下吗?
 楼主| 发表于 2019-12-18 08:11:45 | 显示全部楼层
我特意试了,可能没领会到怎么捕捉技巧吧,还有别的方式吗,正常情况没有捕捉哦,主要还是特殊情况下(非普通直线)的使用问题,谢谢您的回复!
 楼主| 发表于 2019-12-18 08:24:19 | 显示全部楼层
谢谢版主,您的代码说实在的都是关联函数,我每次看到都头疼,因为知道您的函数简洁好用,但是无奈我没法用工具箱(系统非中文)也就没法用您的一系列函数库,有兴趣搞搞多国语言版,或者研究一下能支持非中文系统支持也行哦,所以,您给的回复我也又只能望洋兴叹了,非常感谢您的回复!
这次是缺UKWORD!!!
都是公开的函数!  发表于 2019-12-18 13:04
发表于 2019-12-18 12:38:48 | 显示全部楼层
xj6019 发表于 2019-12-18 08:11
我特意试了,可能没领会到怎么捕捉技巧吧,还有别的方式吗,正常情况没有捕捉哦,主要还是特殊情况下(非 ...
恩明白你的意思了,晚上给你改一下吧
GMT+8, 2026-1-3 07:00 , Processed in 0.167450 second(s), 30 queries , Gzip On.
