查看: 731|回复: 5
[讨论] 代码怎么改填充的种类
发表于 2019-12-26 20:14:49 | 显示全部楼层 |阅读模式
    选择了几个填充以后,怎么用代码改变填充的种类呀,我经常需要把别人的图纸的填充改成SOLID,34号颜色
哪位能给段代码完成这个工作啊,谢谢!!
发表于 2019-12-26 22:51:11 | 显示全部楼层
(defun C:tt (/ dxf name obj ss)
        (if (not (tblobjname "LAYER" "34"))
                        (foreach x (list
        '(0 . "LAYER")
        '(100 . "AcDbSymbolTableRecord")
        '(100 . "AcDbLayerTableRecord")
        '(70 . 0)
        '(2 . "34");图层名
                                (if (/= x nil)
                                        (setq dxf (cons x dxf))
                        (entmake (setq dxf (reverse dxf)))
        (setq ss (ssget '((0 . "HATCH"))))
        (if ss
                (while (setq name (ssname ss 0))
                        (setq obj (vlax-ename->vla-object name))
                        (vla-put-Layer obj "34")
                        (vla-put-Color obj 34)
                        (setq dxf (entget name))
                        (entmod (subst '(2 . "SOLID") (assoc 2 dxf) dxf))
                        (ssdel name ss)
发表于 2019-12-26 20:49:24 | 显示全部楼层
(defun C:tt (/ dxf name ss)
        (if ss
                        (vla-put-Color (vlax-ename->vla-object name) 34)
                        (ssdel name ss)
xj6019 + 1 很给力!
 楼主| 发表于 2019-12-26 22:03:47 | 显示全部楼层
        (if ss
非常感谢,忘了一个事,我是把34号色单独建立了一个图层,我找了个老师的代码,是把填充移动到一个图层的。麻烦在下面的代码基础上,改一下,填充移动到填充图层后,图案种类变成solid可以吗,您的代码很简洁,可以的话用您的代码改一下也行(就是移动到填充图层并变成solid)
麻烦给再修改一下,谢谢了!!
((defun htchlay (lynm )
  (or activedocument
      (setq activedocument (vlax-get-property (vlax-get-acad-object) 'activedocument))
      ); or
  (or blocks
      (setq blocks (vlax-get-property activedocument 'blocks))
      ); or
  (or layers
      (setq layers (vlax-get-property activedocument 'layers))
      ); or
  (if (not
        (vl-catch-all-error-p (vl-catch-all-apply 'vla-item (list layers lynm)))
        ); not
      (vlax-for x blocks
        (vlax-for n x
          (if (equal "AcDbHatch" (vlax-get-property n 'objectname))
            (vl-catch-all-apply 'vlax-put-property (list n 'layer lynm))
            ); if
          ); vlax-for
        ); vlax-for
      ); progn
    ); if
  (vl-cmdf "regen")
  ); defun
(defun c:htc ()
(htchlay  "填充")))
 楼主| 发表于 2019-12-27 08:58:30 | 显示全部楼层
非常非常感谢!!
发表于 2020-1-3 17:28:20 | 显示全部楼层
老师,你好,如果不是SOLID图案,是其他图案,能否增加一项,要拿来替换的图案,比例设为1,不然被替换的图案比例不是1,新的图案替换上去就是原来图案的比例
GMT+8, 2025-5-18 09:53 , Processed in 0.189480 second(s), 29 queries , Gzip On.
