查看: 1029|回复: 11
[提问] 高手帮帮忙
发表于 2019-12-28 11:51:39 | 显示全部楼层 |阅读模式
如图,JMD内标注都被移动过了,不规整,现在想要批量把JMD内注记移动到封闭面中间位置,请大神帮忙
发表于 2019-12-28 20:33:00 | 显示全部楼层
改成居中
  1. (defun c:test1 (/ ss i en ent pt)
  2.   (setq ss (ssget '((0 . "text"))))
  3.   (command "justifytext" ss "" "m")
  4.   (repeat (setq i (sslength ss))
  5.     (setq en  (ssname ss (setq i (1- i)))
  6.           ent (entget en)
  7.           pt  (cdr (assoc 11 ent))
  8.     )
  9.     (vl-cmdf "_.boundary" pt "")
  10.     (vl-cmdf "region" (entlast) "")
  11.     (setq pt (vlax-safearray->list
  12.                (vlax-variant-value
  13.                  (vlax-get-property
  14.                    (vlax-ename->vla-object (entlast))
  15.                    'Centroid
  16.                  )
  17.                )
  18.              )
  19.     )
  20.     (entdel (entlast))
  21.     (setq ent (subst (cons 11 pt) (assoc 11 ent) ent))
  22.     (entmod ent)
  23.     (entupd en)
  24.   )
  25. )
参与人数 1金钱 +20 收起 理由
zhangsk19 + 20 很给力!问题解决了,好厉害
发表于 2019-12-28 21:34:38 | 显示全部楼层
另一个方法
(defun c:test2 (/ ss i obj p1 p2 pt ptt)
  (setq ss (ssget))
    (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
    (vla-getboundingbox obj 'p1 'p2)
    (setq pt (mapcar '(lambda (x y) (* 0.5 (+ x y)))
                     (vlax-safearray->list p1)
                     (vlax-safearray->list p2)
    (setq ptt (vlax-safearray->list
                (vlax-variant-value
                  (vlax-get-property
                    'Centroid
    (entdel (entlast))
    (vla-move obj (vlax-3d-point pt) (vlax-3d-point ptt))
发表于 2019-12-28 12:46:39 | 显示全部楼层
不一定好使
  3.   (repeat (setq i (sslength ss))
  4.     (setq en  (ssname ss (setq i (1- i)))
  5.           ent (entget en)
  6.           pt  (cdr (assoc 10 ent))
  7.     )
  8.     (vl-cmdf "_.boundary" pt "")
  9.     (vl-cmdf "region" (entlast) "")
  10.     (setq pt (vlax-safearray->list
  11.                (vlax-variant-value
  12.                  (vlax-get-property
  13.                    (vlax-ename->vla-object (entlast))
  14.                    'Centroid
  15.                  )
  16.                )
  17.              )
  18.     )
  19.     (entdel (entlast))
  20.     (setq ent (subst (cons 10 pt) (assoc 10 ent) ent))
  21.     (entmod ent)
  22.     (entupd en)
  23.   )
  24. )
发表于 2019-12-28 13:19:06 | 显示全部楼层
CASS内,recass命令研究一下,注意备份原图。
 楼主| 发表于 2019-12-28 16:16:52 | 显示全部楼层
无法运行
 楼主| 发表于 2019-12-28 16:17:40 | 显示全部楼层
重构会很麻烦
发表于 2019-12-28 20:22:01 | 显示全部楼层
发图测试,我这里是可以的
 楼主| 发表于 2019-12-28 20:45:40 | 显示全部楼层
加载程序时怎么提示我输入的字串符有缺陷
发表于 2019-12-28 21:35:26 | 显示全部楼层
zhangsk19 发表于 2019-12-28 20:45
加载程序时怎么提示我输入的字串符有缺陷
拷贝代码没拷贝对吧,自己改一下,也就是个思路
GMT+8, 2025-5-18 09:44 , Processed in 0.201186 second(s), 29 queries , Gzip On.
