查看: 997|回复: 4
[讨论] 标注取整
发表于 2019-12-29 21:28:52 | 显示全部楼层 |阅读模式
各位大佬
能不能帮写一个标注取整的小程序——就是选择(可以框选)部分标注后,把标注数值不是5或者10的,取整为5或者10的整数
发表于 2019-12-30 11:03:37 | 显示全部楼层
修改标注样式应该能是你想要的结果。
发表于 2019-12-29 22:14:34 | 显示全部楼层
发表于 2019-12-30 19:18:48 | 显示全部楼层
(defun ureal (bit kwd msg def / inp);by院长
  (if def
    (setq msg (strcat "\n" msg "<" (rtos def 2) ">: ")
          bit (* 2 (fix (/ bit 2)))
    (setq msg (strcat "\n" msg ": "))
  (initget bit kwd)
  (setq inp (getreal msg))
  (if inp inp def)
;标注取整
(defun c:tt( / ss len i blk)
                                (setq OLDDIMRND (getvar "DIMRND" ))
                                (setq rnd (Ureal 5 "" "舍入值" rnd))
                (if (setq ss (SSGET '((0 . "*Dimension"))))
                                        (setq len (sslength ss)
        i 0)
                                        (repeat len
                                                (setq blk (ssname ss i))
                                                (vla-put-RoundDistance (vlax-ename->vla-object blk ) rnd)
                                                (setq i (1+ i))
                (setvar "DIMRND" OLDDIMRND)
 楼主| 发表于 2019-12-30 21:35:03 | 显示全部楼层
  (if def
系统提示:
输入的字符串有缺陷
GMT+8, 2025-5-18 11:08 , Processed in 0.171473 second(s), 28 queries , Gzip On.
