查看: 1435|回复: 7
[提问] 标注文字提取(急)
发表于 2019-12-30 09:28:02 | 显示全部楼层 |阅读模式
哪个高手帮忙看一下,把标注文字提取到excel以后,怎么合并排序,最好能有一个序号(defun c:ZZC()
(setq ffn (getfiled "写出文件" "" "xls" 1))
(princ "\n选取文字...")
(setq ss (ssget))
(setq ff (open ffn "w"))
(setq i 0)
(repeat (sslength ss)
(setq ssn (ssname ss i))
(setq ssdata (entget ssn))
(setq sstyp (cdr (assoc 0 ssdata)))
(if (or (= sstyp "TEXT") (= sstyp "DIMENSION"))
(setq txt (cdr (assoc 42 ssdata)))
(princ txt ff)
(princ "\n" ff)
(setq i (1+ i))
(close ff)
(princ (strcat "\n写出文件: " ffn))
(prin1)
发表于 2019-12-30 13:54:11 | 显示全部楼层
  • (defun c:tt5 ()
  •   (setq ffn (getfiled "写出文件" "" "xls" 1))
  •   (princ "\n选取文字...")
  •   (setq ss (ssget))
  •   (setq ff (open ffn "w"))
  •   (setq i 0)
  •   (repeat (sslength ss)
  •     (setq ssn (ssname ss i))
  •     (setq ssdata (entget ssn))
  •     (setq sstyp (cdr (assoc 0 ssdata)))
  •     (if (or (= sstyp "TEXT") (= sstyp "DIMENSION"))
  •       (progn
  •         (setq txt (cdr (assoc 42 ssdata)))
  •         (princ (setq i (1+ i)) ff) (princ "\t" ff) (princ txt ff)
  •         (princ "\n" ff)
  •   (close ff)
  •   (princ (strcat "\n写出文件: " ffn))
  •   (prin1)
 楼主| 发表于 2019-12-30 14:10:28 | 显示全部楼层
** Error: 参数类型错误: numberp: nil **
拷贝错了,重新编辑  发表于 2019-12-30 14:19
 楼主| 发表于 2019-12-30 14:21:27 | 显示全部楼层
只是加序号了?没有合并相同的?
 楼主| 发表于 2019-12-30 16:26:49 | 显示全部楼层
能在修改一下吗?
发表于 2019-12-31 09:01:06 | 显示全部楼层
 楼主| 发表于 2019-12-31 14:59:36 | 显示全部楼层
别捣乱,发的什么啊
GMT+8, 2025-5-18 09:51 , Processed in 0.183311 second(s), 26 queries , Gzip On.
