查看: 3184|回复: 8
[JIG] Jig操作拖动墙块
发表于 2020-1-4 11:50:17 | 显示全部楼层 |阅读模式
用的是AutoCAD2018+vs2015写的
代码详见:
AutoCad 二次开发 Jig操作之墙块的拖动
 楼主| 发表于 2020-1-4 11:52:30 | 显示全部楼层
代码在这个地址里:
https://www.cnblogs.com/HelloQLQ/p/12148343.html
发表于 2020-2-9 20:27:52 | 显示全部楼层
楼主加油啊,多出好作品!
发表于 2020-4-22 14:17:18 | 显示全部楼层
楼主大神,少了tospace函数,能否上传上来给大家学习?谢谢!
 楼主| 发表于 2020-4-22 14:20:20 | 显示全部楼层
我去找找看
 楼主| 发表于 2020-4-22 14:25:35 | 显示全部楼层
  1. public static ObjectId ToSpace(this Entity ent, Database db = null, string space = null)
  2.         {
  3.             db = db ?? Application.DocumentManager.MdiActiveDocument.Database;
  4.             var id = ObjectId.Null;
  5.             using (var trans = db.TransactionManager.StartTransaction())
  6.             {
  7.                 var blkTbl = trans.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
  8.                 var mdlSpc = trans.GetObject(blkTbl[space ?? BlockTableRecord.ModelSpace],
  9.                     OpenMode.ForWrite) as BlockTableRecord;
  10.                 id = mdlSpc.AppendEntity(ent);
  11.
  12.                 trans.AddNewlyCreatedDBObject(ent, true);
  13.                 trans.Commit();
  14.             }
  15.             return id;
  16.         }
  17.         /// <summary>
  18.         /// 将实体集合添加到特定空间。
  19.         /// </summary>
  20.         /// <param name="ents"></param>
  21.         /// <param name="db"></param>
  22.         /// <param name="space"></param>
  23.         /// <returns></returns>
  24.         public static ObjectIdCollection ToSpace(this IEnumerable<Entity> ents,
  25.             Database db = null, string space = null)
  26.         {
  27.             db = db ?? Application.DocumentManager.MdiActiveDocument.Database;
  28.             var ids = new ObjectIdCollection();
  29.             using (var trans = db.TransactionManager.StartTransaction())
  30.             {
  31.                 var blkTbl = trans.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
  32.                 var mdlSpc = trans.GetObject(blkTbl[space ?? BlockTableRecord.ModelSpace],
  33.                     OpenMode.ForWrite) as BlockTableRecord;
  34.                 foreach (var ent in ents)
  35.                 {
  36.                     ids.Add(mdlSpc.AppendEntity(ent));
  37.                     trans.AddNewlyCreatedDBObject(ent, true);
  38.                 }
  39.                 trans.Commit();
  40.             }
  41.             return ids;
  42.         }
 楼主| 发表于 2020-4-22 14:26:35 | 显示全部楼层
已经上传了,你自己看一下,是扩展方法。
GMT+8, 2025-5-24 05:10 , Processed in 0.182353 second(s), 24 queries , Gzip On.
