查看: 859|回复: 2
[提问] 各位老师,如何才能实现输出带特定字符开头的图层列表
发表于 2020-1-14 07:52:20 | 显示全部楼层 |阅读模式
;===========================================================================图层列表插件======================================================
;===========================该插件显示全部图层列表,能否显示特定字符开头的图层列表 ,如y开头的(特定字符可以自己输入)========================
(defun c:tclb(/ LST N PT)
(command "undo" "be")
(defun TABLE (S / D R)
(while (setq D (tblnext S (null D)))
(setq R (cons (cdr (assoc 2 D)) R))))
(setq LST (reverse (TABLE "LAYER")))
(setq PT (getpoint "请指定文字插入點:") N 0)
(foreach NAME LST (entmake (list '(0 . "TEXT") (cons 8 NAME) '(100 . "AcDbText")
(cons 10 (list (car PT) (- (cadr PT) N))) ' (40 . 6) (cons 1 NAME)))
(setq N (+ N 10.0)))
(command "zoom" "O" (entlast) "")
(command "undo" "e")
(princ))
发表于 2020-1-14 10:35:35 | 显示全部楼层
 楼主| 发表于 2020-2-13 13:59:38 | 显示全部楼层
各位老师:
      我想输出带特定字符的图层列表,一直没有思路,麻烦老师们指教!
                                      谢谢
GMT+8, 2025-5-2 15:03 , Processed in 0.167322 second(s), 26 queries , Gzip On.
