查看: 1118|回复: 4
[提问] 反向替换块,替换以后会导致动态块丢失动态属性,求助!
发表于 2020-1-15 10:20:52 | 显示全部楼层 |阅读模式
初衷:经常使用块作图,但是一张图纸可能两个人在修改,两个人都修改了一部分块,想直接在自己的文件里把别人修改的块替换过来,论坛里的大佬提供了一个反向替换块的方案,很好用,但是还有有点bug,就是如果替换块中有动态块,直接导致动态块失效,动态属性用不了。求高手完善一下,不胜感激。
附上源码,供参考。
MM-替换同名块
(defun c:MM (/ DWGNAME      DBXDOC       ACVER
                     DBXMODELSPACE             BLOCKS
                     DOC          DBXBLOCKNAMES
                     OBJS
  (setq DwgName (GETFILED "选择引入图块的DWG文件" "" "dwg" 4))
  (if (and
        DwgName
        (not
          (equal
            (strcase DwgName)
            (strcase (strcat (getvar "dwgprefix") (getvar "dwgname")))
      (setq
        DBXDOC (vla-GetInterfaceObject
                 (vlax-get-acad-object)
                 (if (< (setq acVer (atoi (getvar "ACADVER"))) 16)
                   "ObjectDBX.AxDbDocument"
                   (strcat "ObjectDBX.AxDbDocument." (itoa acVer))
      (vla-open DBXDOC DWGNAME)
      (setq DBXModelSpace (vla-get-ModelSpace DBXDOC))
      (setq blocks (vla-get-blocks
                     (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
      (vlax-for blk (vla-get-blocks DBXDOC)
        (if (not (or (eq :vlax-true (vla-get-isXRef blk))
                     (eq :vlax-true (vla-get-isLayout blk))
                     (= "*U" (substr (vla-get-name blk) 1 2))
                     (= "*D" (substr (vla-get-name blk) 1 2))
                     (= "*T" (substr (vla-get-name blk) 1 2))
          (setq dbxblocknames (cons (vla-get-name blk) dbxblocknames))
      (setq dbxblocknames
             (vl-remove-if-not
               '(lambda (x) (TBLSEARCH "BLOCK" x))
               dbxblocknames
      (if dbxblocknames
          (foreach block dbxblocknames
            (vlax-for obj (vla-item blocks block)
              (vla-delete obj)
            (setq objs nil)
            (vlax-invoke
              dbxDoc
              'CopyObjects
              (vlax-for a
                (vla-item (vla-get-blocks DBXDOC) block)
                (setq objs (cons a objs))
          (vla-regen doc :vlax-true)
          (prompt (strcat "\n更新了" (itoa (length dbxblocknames)) "个图块!"))
        (prompt "\n没有可更新的图块!")
      (vlax-release-object DBXDOC)
 楼主| 发表于 2020-1-15 16:45:04 | 显示全部楼层
这个是很多作图人的痛点,希望大神关注一下
发表于 2020-4-21 07:29:15 | 显示全部楼层
我也一直在找关于动态块自定义属性
发表于 2020-7-10 23:52:28 | 显示全部楼层
这个代码运行不了啊
发表于 2025-1-14 18:39:46 来自手机 | 显示全部楼层
用ctrl+2就可以
GMT+8, 2025-5-1 20:42 , Processed in 0.191350 second(s), 25 queries , Gzip On.
