查看: 1483|回复: 5
[提问] entmake生成块怎样包含属性块
发表于 2020-1-15 10:28:08 来自手机 | 显示全部楼层 |阅读模式
用entmake做块,当嵌套包含属性块时会提示无效复杂对象。有没有方法解决呢?
 楼主| 发表于 2020-1-15 10:29:52 来自手机 | 显示全部楼层
用的代码是lisp分类学习手册的函数
 楼主| 发表于 2020-1-15 10:32:54 | 显示全部楼层
  1. 函数:
  2. mc-make-unname-block
  3. 功能:
  4. 生成无名图块
  5. 函数代码:
  6. (defun mc-make-unname-block(ss / count entlist ent blk)
  7.   (entmake '((0 . "BLOCK")   (2 . "*U")    (70 . 1)    (10 0 0 0)     ))
  8.   (setq count 0)
  9.   (repeat (sslength ss)
  10.     (setq entlist(entget(setq ent(ssname ss  count))))
  11.     (setq count (1+ count))
  12.     (entmake entlist)
  13.     )
  14.   (setq count 0)
  15.   (repeat(sslength ss)
  16.     (setq ent(ssname ss count))
  17.     (setq count (1+ count))
  18.     (entdel ent)
  19.     )
  20.   (setq blk(entmake '((0 . "ENDBLK"))))
  21.   (if (princ blk)
  22.   (entmake (list (cons 0  "INSERT")
  23.   (cons 2 blk)
  24.      (cons 10 '(0 0 0))    ))
  25.     )
  26.   blk
  27.   )语法:
  28. (mc-make-unname-block ss)
  29. 参数:
  30. ss:选择集
  31. 返回值:
  32. 无名块
  33. 示例:
  34. (mc-make-unname-block (ssget))
  35. 说明:
  36. 函数对选择集中存在具有属性的图块及复杂多义线无效
发表于 2020-1-15 14:16:33 | 显示全部楼层
属性块不能做成匿名块,但可以做成多重引用匿名块
(defun MIntoBlock ( / ss adoc blk obj objs pts ptc i )
  (while (null (setq ss (ssget))))
  (setq pts (get-outbox ss))
  (setq ptc (get-midpt (car pts) (cadr pts)))
  (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
  (setq blk (vla-add (vla-get-blocks adoc) (vlax-3d-point ptc) "*U" ))
  (repeat (setq i (sslength ss))
    (setq obj (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
    (setq objs (cons obj objs))
  (vlax-invoke adoc 'copyobjects objs blk)
  (mapcar 'vla-delete objs)
  (vla-AddMInsertBlock (vla-get-modelspace adoc) (vlax-3d-point ptc) (vla-get-name blk) 1 1 1 0 2 2 0 0)
发表于 2020-3-18 00:43:35 | 显示全部楼层
(defun MIntoBlock ( / ss adoc blk obj objs pts ptc i ...
这个代码不错,但是做成了咋炸开呢?
发表于 2020-3-19 10:56:55 | 显示全部楼层
尘缘一生 发表于 2020-3-18 00:43
这个代码不错,但是做成了咋炸开呢?
(defun MIntoBlockExplode ( / ss enf ent n x y )
  (while (null (setq ss (ssget ":s" (list (cons 0 "INSERT"))))))
  (repeat (setq n (sslength ss))
    (setq ent (entget (ssname ss (setq n (1- n)))))
    (mapcar '(lambda ( x y ) (setq ent (subst x y ent)))
            (list (cons 44 0) (cons 45 0) (cons 70 0) (cons 71 0))
            (list (assoc 44 ent) (assoc 45 ent) (assoc 70 ent) (assoc 71 ent))
    (entmod ent)
    (setq ent (entget (ssname ss n)))
    (entdel (ssname ss n))
    (entmake (subst (cons 100 "AcDbBlockReference") (cons 100 "AcDbMInsertBlock") ent))
    (setq enf (entlast))
    (vla-explode (vlax-ename->vla-object enf))
    (entdel enf)
GMT+8, 2025-5-18 07:56 , Processed in 0.209614 second(s), 25 queries , Gzip On.
