查看: 5171|回复: 22
[经验] function和quote的区别
发表于 2020-2-18 14:28:57 | 显示全部楼层 |阅读模式
先看例子
(setq  TT (EVAL (quote(LAMBDA (K ) (ALERT K ) ) ) ))
(TT "dd" )
编译以后是这样的:
Offset         0    1   2  3   4  5   6   7   8    9  A    B  C   D  E  F
00000000   0D 0A 20 46 41 53 34 2D  46 49 4C 45 20 3B 20 44      FAS4-FILE ; D
00000010   6F 20 6E 6F 74 20 63 68  61 6E 67 65 20 69 74 21   o not change it!
00000020   0D 0A 31 0D 0A 31 20 24  20 24 0D 0A 31 32 33 20    1  1 $ $  123
00000030   36 20 24 14 01 01 01 00  32 00 32 22 2A 39 01 00   6 $     2 2"*9
00000040   55 01 00 02 00 64 64 5B  54 54 00 45 56 41 4C 00   U    dd[TT EVAL
00000050   00 5B 4C 41 4D 42 44 41  00 00 5B 4B 00 00 39 01    [LAMBDA  [K  9
00000060   00 5B 41 4C 45 52 54 00  00 5B 4B 00 00 39 02 00    [ALERT  [K  9
00000070   39 03 00 01 01 43 00 00  06 00 0A 01 5C 00 00 43   9    C      \  C
00000080   00 00 01 00 0A 01 43 06  00 00 00 1C 14 01 00 00         C
00000090   00 09 05 00 0A 09 04 00  34 00 07 35 01 03 00 03           4  5
000000A0   0B 06 02 00 0A 09 01 00  35 01 02 00 03 16 15 00           5
000000B0   B6 81 1A 52 B3 0A 3B 66  61 73 34 20 63 72 75 6E   ? R?;fas4 crun
000000C0   63 68 0A 3B 24 3B 41 32  2F 31 38 2F 32 30         ch ;$;A2/18/20
(setq tt (eval(function(lambda (k)    (alert k)   ))))
(tt "dd")
这两句编译后是这样:
00000020   0D 0A 32 36 0D 0A 33 20  24 14 01 01 01 00 09 02     26  3 $
00000030   00 5C 00 00 18 03 00 03  02 00 35 01 01 00 03 19    \        5
00000040   01 00 16
24 0D 0A 31 33  39 20 37 20 24 14 01 01      $  139 7 $
00000050   01 00 32 00 32 2A 2A 39  01 00 55 01 00 02 00 64     2 2**9  U    d
00000060   64 5B 54 54 00 45 56 41  4C 00 00 56 6B 77 6F 74   d[TT EVAL  Vkwot
00000070   65 00 00 01 01 43 00 00  06 00 0A 32 00 32 1A 2A   e    C     2 2 *
00000080   39 01 00 5B 41 4C 45 52  54 00 4B 00 00 5C 00 00   9  [ALERT K  \
00000090   43 00 00 03 00 0A 5C 00  00 32 00 5B 2D 6C 61 6D   C     \  2 [-lam
000000A0   62 64 61 2D 00 00 3A 01  43 06 00 01 00 1C 14 01   bda-  : C
000000B0   00 00 00 09 05 00 0A 57  00 00 00 00 09 06 00 51          W       Q
000000C0   01 04 00 01 00 35 01 03  00 03 0B 06 02 00 0A 09        5
000000D0   01 00 35 01 02 00 03 16  18 00 A9 8A FC F9 EA 3D     5       ⿰?
000000E0   9D EE 0A 3B 66 61 73 34  20 63 72 75 6E 63 68 0A    ?;fas4 crunch
000000F0   3B 24 3B 41 32 2F 31 38  2F 32 30                  ;$;A2/18/20
可以看出以下几点:
1.用quote时没有定义函数,蓝色字符为1,1,意思是函数部分只有一个字节长,含有一个符号。
   用function是定义了一个函数,-lambda-,函数内容紫红色部分,蓝色字符 26 3说明函数部分的长度是26个字节,含有3个符号。
2.用quote时 , (alert k) 是作为一个表来解释运行的。绿色的39 02 00说明这个表有两个元素
3.用function时, alert和 k是两个独立的字符串。
结论:用quote时lambda没有编译成函数,是解释运行,速度慢。用function时,lambda被编译成了一个函数,可以进行优化,速度快。
所谓优化,就是可以快速、直接访问函数入口地址,不需要查找函数名对应的地址后再调用。
有的反编译工具,没有正确处理function,导致用了这个函数的程序不能被反编译。
自贡黄明儒 + 1 赞一个!
发表于 2022-7-14 11:39:12 | 显示全部楼层
确实如楼主所说,《明经通道》翻译的autolisp函数对这个函数说明如下:
function
通知 Visual LISP 编译器将参数作为内置函数进行链接和优化
(function symbol | lambda-expr)
function 函数与 quote 函数相同,但它将通知 Visual LISP 编译器将参数视为内部函数或用 defun 定义的函数,对其进行链接和优化。
由 function 引用的经过编译的 lambda 表达式加载到 Visual LISP IDE 时,将包含调试信息。
参数
symbol
命名函数的符号。
lambda-expr
如下格式的表达式:
(LAMBDA arguments {S-expression}* )
返回值
表达式的求值结果。
示例
下列代码中,Visual LISP 编译器不能优化被引用的 lambda 表达式:
(mapcar
  '(lambda (x) (* x x))
       '(1 2 3))
向表达式中添加 function 函数后,编译器可对 lambda 表达式进行优化。例如:
(mapcar
   (function (lambda (x) (* x x)))
      '(1 2 3))
发表于 2022-7-14 11:51:00 | 显示全部楼层
我上面那个语句,编译后看码似乎和楼主用function后是差不多的,肯定不是第一种结果
如果用list是不优化的,那么下面这个tt1命令怎么写才对呢?tt2是可以正常运行的
  1. (defun ttfunc (func / )
  2.    (eval func)
  3. )
  4. (defun c:tt1()
  5.   (ttfunc (function (lambda() (princ "\test"))))
  6. )
  7. (defun c:tt2()
  8.   (ttfunc (list (lambda() (princ "\test"))))
  9. )
发表于 2022-7-13 21:30:30 | 显示全部楼层
这么写,编译优化了吗?function定义的函数,似乎没法作为参数传递到其它函数中
  1. (setq  TT (list (LAMBDA ( ) (ALERT K ) ) ) )
  2. (setq k "dd")
  3. (eval TT)
发表于 2020-2-18 16:03:03 来自手机 | 显示全部楼层
硬核技术贴
发表于 2020-2-19 11:14:26 | 显示全部楼层
确实啊,出错在这个地方很多。
发表于 2020-2-19 11:16:44 | 显示全部楼层
硬核技术贴
发表于 2020-2-19 17:52:59 | 显示全部楼层
意思是用function效率更高?我每次都是用的'(lambda(x) )   这个'是不是相当于quote
 楼主| 发表于 2020-2-19 22:28:25 | 显示全部楼层
确实如此,function是为优化而生的
 楼主| 发表于 2020-2-19 22:29:25 | 显示全部楼层
烟盒迷唇 发表于 2020-2-19 11:14
确实啊,出错在这个地方很多。
可以把出错的文件发给我,帮你研究解决方法
发表于 2020-2-20 17:10:04 | 显示全部楼层
主要是感觉写'比较方便    '是不是等于quote
 楼主| 发表于 2020-2-20 21:35:48 | 显示全部楼层
'不完全等于quote,有区别
发表于 2020-2-20 22:31:08 | 显示全部楼层
牛气,有没有系统的研究成果供学习啊!
GMT+8, 2025-6-22 05:37 , Processed in 0.174910 second(s), 28 queries , Gzip On.
