查看: 2529|回复: 8
[提问] 缩放命令改造
发表于 2020-2-20 23:08:19 | 显示全部楼层 |阅读模式
请才高手
我想把缩放命令scale进行改造,用参照的方法,省略输入R参数,怎么改造?
谁有办法改造这个原生命令?
发表于 2020-2-21 13:00:03 | 显示全部楼层
(DEFUN C:TT()
  (if (and
        (setq ss (ssget))
        (setq pt (getpoint "指定指点"))
    (COMMAND "scale" ss "" pt "R" pt pause)
 楼主| 发表于 2020-2-22 12:03:52 | 显示全部楼层
永不言弃 发表于 2020-2-21 13:00
(DEFUN C:TT()
  (if (and
        (setq ss (ssget))
感谢
发表于 2020-2-22 20:15:36 | 显示全部楼层
;;;          放大缩小 倍数       ;;;;;;;;;;
(defun c:V01  () (setq rr (ssget)) (command "scale" rr "" pause "0.1" )  (princ "\n缩小0.1倍")(princ))
(defun c:V02  () (setq rr (ssget)) (command "scale" rr "" pause "0.2" )  (princ "\n缩小0.2倍")(princ))
(defun c:V03  () (setq rr (ssget)) (command "scale" rr "" pause "0.3" )  (princ "\n缩小0.3倍")(princ))
(defun c:V04  () (setq rr (ssget)) (command "scale" rr "" pause "0.4" )  (princ "\n缩小0.4倍")(princ))
(defun c:V05  () (setq rr (ssget)) (command "scale" rr "" pause "0.5" )  (princ "\n缩小0.5倍")(princ))
(defun c:V06  () (setq rr (ssget)) (command "scale" rr "" pause "0.6" )  (princ "\n缩小0.6倍")(princ))
(defun c:V07  () (setq rr (ssget)) (command "scale" rr "" pause "0.7" )  (princ "\n缩小0.7倍")(princ))
(defun c:V08  () (setq rr (ssget)) (command "scale" rr "" pause "0.8" )  (princ "\n缩小0.8倍")(princ))
(defun c:V09  () (setq rr (ssget)) (command "scale" rr "" pause "0.9" )  (princ "\n缩小0.9倍")(princ))
(defun c:V1    () (setq rr (ssget)) (command "scale" rr "" pause "1" )  (princ "\n放大1倍")(princ))
(defun c:V2    () (setq rr (ssget)) (command "scale" rr "" pause "2" )  (princ "\n放大2倍")(princ))
(defun c:V3    () (setq rr (ssget)) (command "scale" rr "" pause "3" )  (princ "\n放大3倍")(princ))
(defun c:V4    () (setq rr (ssget)) (command "scale" rr "" pause "4" )  (princ "\n放大4倍")(princ))
(defun c:V5    () (setq rr (ssget)) (command "scale" rr "" pause "5" )  (princ "\n放大5倍")(princ))
(defun c:V6    () (setq rr (ssget)) (command "scale" rr "" pause "6" )  (princ "\n放大6倍")(princ))
(defun c:V7    () (setq rr (ssget)) (command "scale" rr "" pause "7" )  (princ "\n放大7倍")(princ))
(defun c:V8    () (setq rr (ssget)) (command "scale" rr "" pause "8" )  (princ "\n放大8倍")(princ))
(defun c:V9    () (setq rr (ssget)) (command "scale" rr "" pause "9" )  (princ "\n放大9倍")(princ))
发表于 2020-2-22 20:16:18 | 显示全部楼层
直接输入放大倍数的命令 好多了
发表于 2020-2-24 17:31:18 | 显示全部楼层
ninja37 发表于 2020-2-22 20:16
直接输入放大倍数的命令 好多了
你这种定义方法如果要定义一亿种倍数(任何实数),是否得写一亿条函数?
发表于 2020-2-26 12:23:43 | 显示全部楼层
一般放到1-10倍  做20个命令 绰绰有余了   就算这1-10倍很多都用的少   什么6倍7倍    如果有小数倍数或者特殊倍数再老老实实用SC命令    可能是行业不同    我这个行业完全够了
发表于 2022-12-24 10:28:24 | 显示全部楼层
行业不同    我这个行业完全够了
发表于 2022-12-24 22:33:22 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-11-13 04:43 , Processed in 0.177226 second(s), 27 queries , Gzip On.
