查看: 1850|回复: 3
求救:关于选择集中AddItems加入已经绘制的图形错误
发表于 2020-3-7 11:35:30 | 显示全部楼层 |阅读模式
  1. '创建临时的选择集用户保存显示范围的画叉和数字编号
  2.         Dim SSetOfShow As Object
  3.         Dim pandan As Boolean
  4.         For Each SSetOfShow In objDoc.SelectionSets
  5.             If SSetOfShow.Name = "SSetName" Then
  6.                 pandan = True
  7.                 Exit For
  8.             End If
  9.         Next
  10.         '判断选择集是否存在
  11.         If pandan Then
  12.             SSetOfShow.Delete                                         '创建集合,如集存在,则删除,新建
  13.         End If
  14.         SSetOfShow = objDoc.SelectionSets.Add("SSetName")        '新建选择集
  15.         errTest = True
  16.         '下面的代码在模型空间的每个图
  17.         Dim objEntity(0) As Object
  18.         Dim pt1 As Object
  19.         Dim pt2 As Object
  20.         Dim pt3(2) As Double
  21.         Dim pt4(2) As Double
  22.         Dim ptCen(2) As Double
  23.         Dim i As Integer
  24.         Dim mx As Integer = 0
  25.         For i = 0 To UBound(ptMin)
  26.             pt1 = ptMin(i) : pt2 = ptMax(i)
  27.             pt3(0) = pt1(0) : pt3(1) = pt2(1) : pt3(2) = 0
  28.             pt4(0) = pt2(0) : pt4(1) = pt1(1) : pt4(2) = 0
  29.             ptCen(0) = (pt1(0) + pt2(0)) / 2 : ptCen(1) = (pt1(1) + pt2(1)) / 2 : ptCen(2) = (pt1(2) + pt2(2)) / 2
  30.             objEntity(0) = objDoc.ModelSpace.AddLine(pt1, pt2)
  31.             objEntity(0).Color = 1
  32.             objEntity(0).Update
  33. <font color="#ff0000">            SSetOfShow.AddItems(objEntity)  执行到这里时出错</font>
  34.             objEntity(0) = objDoc.ModelSpace.AddLine(pt3, pt4)
  35.             objEntity(0).Color = 1
  36.             objEntity(0).Update
  37. <font color="#ff0000">            ' SSetOfShow.AddItems(objEntity)</font>
  38.             objEntity(0) = objDoc.ModelSpace.AddText(CStr(mx), ptCen, SSetOfShow.Item(SSetOfShow.Count - 1).Length / 5)
  39.             objEntity(0).Color = 1
  40.             objEntity(0).Update
  41. <font color="#ff0000">            'SSetOfShow.AddItems(objEntity)</font>
  42.             mx = mx + 1
  43.         Next i
每次直行到SSetOfShow.AddItems(objEntity)  时候出错,错误信息是System.ArgumentException:“参数 pSelSet (位于 AddItems 中) 无效”
求指点一下,
 楼主| 发表于 2020-3-7 16:48:35 | 显示全部楼层
换了个思路,解决了
 楼主| 发表于 2022-7-28 22:07:19 | 显示全部楼层
  1.     For i = 0 To UBound(ptMin)
  2.         pt1 = ptMin(i): pt2 = ptMax(i)
  3.         pt3(0) = pt1(0): pt3(1) = pt2(1): pt3(2) = 0
  4.         pt4(0) = pt2(0): pt4(1) = pt1(1): pt4(2) = 0
  5.         ptCen(0) = (pt1(0) + pt2(0)) / 2: ptCen(1) = (pt1(1) + pt2(1)) / 2: ptCen(2) = (pt1(2) + pt2(2)) / 2
  6.         Set objEntity(0) = objDoc.modelspace.AddLine(pt1, pt2)
  7.             objEntity(0).color = 1
  8.             objEntity(0).Update
  9.         SSetOfShow.AddItems objEntity
  10.         Set objEntity(0) = objDoc.modelspace.AddLine(pt3, pt4)
  11.             objEntity(0).color = 1
  12.             objEntity(0).Update
  13.         SSetOfShow.AddItems objEntity
  14.         Set objEntity(0) = objDoc.modelspace.AddText(CStr(mx), ptCen, SSetOfShow.Item(SSetOfShow.Count - 1).Length / 5)
  15.             objEntity(0).color = 1
  16.             objEntity(0).styleName = "Standard" '设置标准字体样式
  17.             objEntity(0).Update
  18.         SSetOfShow.AddItems objEntity
  19.         mx = mx + 1
  20.     Next i
复制代码
主要原因还是CAD没有用户管理权限
发表于 2022-7-29 14:30:54 | 显示全部楼层
注意那个objEntity参数是需要一个数组。
GMT+8, 2025-5-22 16:45 , Processed in 0.155652 second(s), 23 queries , Gzip On.
