查看: 1146|回复: 9
[提问] 如何删除多行文字中特定类型的字符?
发表于 2020-3-9 10:44:53 | 显示全部楼层 |阅读模式
3明经币
如下图:
如何删除多行文字中特定类型的字符?
删除多行文字中的公差,公差值的颜色和字高不是固定的,但都是堆叠的
附件: 您需要 登录 才可以下载或查看,没有账号?注册
 楼主| 发表于 2020-3-9 20:43:08 | 显示全部楼层
路过的大师指点一下啦
发表于 2020-3-9 21:32:47 | 显示全部楼层
{\\fSimSun|b0|i0|c134|p2;顶板}610×75{\\H0.5x;\\T0.95;\\C201;\\S+0.1^ 0;}×18{\\H0.5x;\\T0.95;\\C201;\\S+0.04^ 0;}
{\\fSimSun|b0|i0|c134|p2;顶板}610×75×18
;;测试
(vla-put-TextString (vlax-ename->vla-object (car (entsel))) "{\\fSimSun|b0|i0|c134|p2;顶板}610×75×18")
移除定位字符串{\\H0.5x;\\T0.95;\\C201;\\S+0.04^ 0;}部分数据
_$ (vl-string-position (ascii"z") "azbdc")1_$ (vl-string-position 122"azbzc")1_$ (vl-string-position (ascii"x") "azbzc")nil
The search string used            in the following example contains two “z” characters. Reading            from left to right, with the first character being displacement            0, there is one z at displacement 1 and another z at displacement            3:
_$ (vl-string-position (ascii"z") "azbzlmnqc")1
Searching from left to            right (the default), the “z” in position 1 is            the first one vl-string-position encounters.            But when searching from right to left, as in the following example,            the “z” in position 3 is the first one encountered:
_$ (vl-string-position (ascii"z") "azbzlmnqc" nil t)3
 楼主| 发表于 2020-3-10 09:00:38 | 显示全部楼层
1291500406 发表于 2020-3-9 21:32
{\\fSimSun|b0|i0|c134|p2;顶板}610×75{\\H0.5x;\\T0.95;\\C201;\\S+0.1^ 0;}×18{\\H0.5x;\\T0.95;\\C201 ...
太深奥了,看不懂啊
我发现,如果不理会汉字部分,只要把 {} 成对的 大括弧 里面的所有字符以及大括弧本身全部删除,这样应该容易一些吧?是不是要用正则呢?
发表于 2020-3-10 09:24:05 | 显示全部楼层
       '删除堆迭格式
       'RE.Pattern = "\\S(.[^;]*)(\^|#|\\)(.[^;]*);"
       's = RE.Replace(s, "$1$3")
       '上标下标分开
       'RE.Pattern = "\\S(.[^;]*)(\^|#|\\);"
       's = RE.Replace(s, "$1")
       'RE.Pattern = "\\S\^(.[^;]*);"
       '上下标分数一起
       'RE.Pattern = "\\S((.[^;]*)(\^|#|\\)|(\^|#|\\)(.[^;]*));"
用正则相当简单。{}是格式的意思,格式不仅仅是堆叠。
发表于 2020-3-10 09:45:46 | 显示全部楼层
(defun c:tt (/ lst n name str t-string-separated txt)
        (defun T-string-separated (str del / lst pos)
                (if (/= str nil)
                                (while (setq pos (vl-string-search del str))
                                        (setq
                                                lst (cons (substr str 1 pos) lst)
                                                str (substr str (+ pos 1 (strlen del)))
                                (reverse (cons str lst))
        (if (setq name(car (entsel)))
                        (setq txt (vla-get-TextString (vlax-ename->vla-object name)))
                        (setq lst (T-string-separated txt "}"))
                        (setq n 0)
                        (foreach x lst
                                (if (= n 0)
                                        (setq str (substr x (+ (vl-string-search ";" x) 2)))
                                        (if (vl-string-search "{" x)
                                                (setq str (strcat str (car (T-string-separated x "{"))))
                                (setq n (1+ n))
        str
 楼主| 发表于 2020-3-10 10:14:58 | 显示全部楼层
mikewolf2k 发表于 2020-3-10 09:24
'删除堆迭格式
       's = RE.Replace(s ...
谢谢 mikewolf2k 版,以前只在安卓系统的 tasker 里玩过一下正则,语法跟这个一样,只是在lsp里不知道要怎么写,还望多多指教
 楼主| 发表于 2020-3-10 10:24:58 | 显示全部楼层
        (defun T-string-separated (str del / lst pos ...
非常感谢 taoyi0727 大师的回复,这个效果可以,不知道是否方便改成通用一点的呢,因为公差和汉字的所在位置有时候会不一样
发表于 2020-3-10 11:11:02 | 显示全部楼层
669423907 发表于 2020-3-10 10:24
非常感谢 taoyi0727 大师的回复,这个效果可以,不知道是否方便改成通用一点的呢,因为公差和汉字的所在 ...
(defun c:tt (/ a ang color distance-pt height high last-name layer lst n name-new-pt name-pt obj pt ss str stylename t-string-separated txt)
                (if (/= str nil)
                                        (setq
        (if (and
                                (setq ss (ssget '((0 . "MTEXT"))))
                                (setq pt (getpoint "\n请点取插入位置"))
                        (setq a -1)
                        (repeat (sslength ss)
                                (setq obj (vlax-ename->vla-object (ssname ss (setq a (1+ a)))))
                                (setq name-pt (safearray-value (variant-value (vla-get-InsertionPoint obj))))
                                (setq color (vla-get-Color obj))
                                (setq Height (vla-get-Height obj))
                                (setq Layer (vla-get-Layer obj))
                                (setq StyleName (vla-get-StyleName obj))
                                (setq txt (vla-get-TextString obj))
                                (setq n 0)
                                (foreach x lst
                                        (if (= n 0)
                                        (setq n (1+ n))
                                (if (not (and ang distance-pt))
                                                (setq ang (angle name-pt pt))
                                                (setq distance-pt (distance name-pt pt))
                                (setq name-new-pt (polar name-pt ang distance-pt))
                                (setq last-name (entlast))
                                (entmake (list
        '(0 . "MTEXT")
        '(100 . "AcDbEntity")
        '(100 . "AcDbMText")
        '(7 . "Standard")
        (cons 1 str)
        (cons 10 name-new-pt)
                                (if (/= (entlast) last-name)
                                                (setq obj (vlax-ename->vla-object (entlast)))
                                                (vla-put-StyleName obj StyleName)
                                                (vla-put-Color obj color)
                                                (vla-put-Height obj Height)
                                                (vla-put-Layer obj Layer)
水平也只有这样了
不会正则
669423907 + 1 谢谢大师热情帮助
发表于 2020-3-10 11:19:52 | 显示全部楼层
GMT+8, 2025-5-18 07:55 , Processed in 0.249391 second(s), 25 queries , Gzip On.
