查看: 1655|回复: 19
[提问] 无名块插入后(entlast),马上炸开怎么写?
发表于 2020-3-10 10:56:45 | 显示全部楼层 |阅读模式
如题:
插入无名块后(entlast)
怎么句代码紧跟上分解炸开?
发表于 2020-3-10 21:10:54 | 显示全部楼层
试试这个:
(defun c:xx(/ ssx *error* ent gr i msg n qf ss)
(setq ssx (ssget"i"))
(defun *error* (msg)
(setvar "qaflags" qf)
(princ msg))
(setq qf (getvar "qaflags"))
(setvar "qaflags" 1)
(setvar 'nomutt 1)
(princ "\n 选择要分解的块或组")
(setq ss (ssget))
(setvar 'nomutt 0)
(setq n (sslength ss))
(command "undo" "be")
(setq i (- n 1))
(repeat n                               ; 先删除组
(setq ent (ssname ss i))
(setq gr (cdr (assoc 0 (entget (cdr (assoc 330 (entget ent)))))))
(if (= "GROUP" gr)
(entdel (cdr (assoc 330 (entget ent)))))
(setq i (1- i)))
(while ;再炸开嵌套块
(if (not ssx)(setq ss (ssget "p" '((0 . "insert,hatch"))))(setq ss (ssget "p" '((0 . "insert")))) )
(command ".explode" ss ""))
(command "undo" "e")
(princ))
发表于 2020-3-11 13:43:29 | 显示全部楼层
试试下面这个能不能实现你的要求。也是建立无名块,插入后,炸开。
(defun greaddrag(a)
   (if (not greadss) (VL-EXIT-WITH-VALUE 0))
   (if (not greadpt0) (VL-EXIT-WITH-VALUE 0))
   (MakeUnNameBlock greadss greadpt0)
   (setq greadent (entlast))
   (setq greadsent (entget greadent) )
   (setq gr-tag T grtag T)
   (while grtag
      (setq grre (grread t 15 0))
      (setq code (car grre) snapt (cadr grre))
      (cond ((= code 3) (setq grtag nil) (command "explode" greadent) )
            ((= code 5)
             (redraw)
             (redraw greadent 2)
             (setq snapt (osnappt  greadent snapt))
             (entmod (setq greadsent (subst (cons 10 snapt) (assoc 10 greadsent) greadsent)))
             (redraw greadent 1)
           ((member code '(11 25)) (setq grtag nil) (setq gr-tag nil) (entdel greadent) )
   (redraw)
   (vl-cmdf "-purge" "B" "*U*" "n")
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=181091&page=1&extra=#pid860529  发表于 2020-3-12 16:20
我的路子代码已解决,代码还没得及实验。  发表于 2020-3-12 00:18
 楼主| 发表于 2020-3-11 11:57:24 | 显示全部楼层
669423907 发表于 2020-3-11 08:25
错误: no function definition: EN2OBJ
;;;常量定义
(setq *Acad*           (vlax-get-acad-object)
        *AcDocument* (vla-get-activedocument *Acad*)  ; 获取当前图档指针
        *Model-Space* (vla-get-modelspace *AcDocument*)
        *Paper-Space* (vla-get-PaperSpace *AcDocument*)
        pi2           (* pi 0.5)
        pi4           (* pi 0.25)
        3pi4         (* 0.75 pi)
        2pi           (* pi 2.0)
        3pi2         (* 3pi4 2.0)  ;; (* 1.5 pi)
        5pi4   (+ pi pi4)  ;;(* 1.25 pi)
        7pi4   (+ 3pi2 pi4) ;;(* 1.75 pi)
  • ;;返回 obj的 vla对象名-------(一级)-----------------------------------
  • (defun en2obj (object)
  •   (cond
  •     ((= (type object) 'vla-object)
  •       object
  •     ((= (type object) 'ename)
  •       (vlax-ename->vla-object object)
 楼主| 发表于 2020-3-10 20:14:47 | 显示全部楼层
问题简单到不值得看来,下面代码不能爆破刚插入的无名块,应该行啊
 楼主| 发表于 2020-3-10 21:25:49 | 显示全部楼层
669423907 发表于 2020-3-10 21:10
试试这个:
成功的,这个行,需要改写下,不要选择了,插入就炸。
发表于 2020-3-10 22:15:50 | 显示全部楼层
在才入块的程序的后面加入
(setq ss (ssadd (entlast) (ssadd)))
(command"select"ss"")
(sssetfirst nil ss)
(c:xx)
 楼主| 发表于 2020-3-10 22:22:31 | 显示全部楼层
669423907 发表于 2020-3-10 22:15
在才入块的程序的后面加入
我发个程序,你帮忙看看,怎么无名块跟着炸开。这个程序很有用,就是选择,跟随鼠标移动函数,用无名块,可是移动后还是个块,非常恶心。
发表于 2020-3-10 22:30:16 | 显示全部楼层
no function definition: SL:-ERASE
少 SL:-ERASE
发上了,忘了加上  发表于 2020-3-10 22:34
发表于 2020-3-10 22:39:51 | 显示全部楼层
少 SS-ENLST
你试试在插入块后加入:
(while(=(getvar "cmdactive")1)(command"\\")) ;命令结束后,继续往下执行
(sssetfirst nil ss)
(c:xx)
 楼主| 发表于 2020-3-10 22:44:50 | 显示全部楼层
669423907 发表于 2020-3-10 22:39
少 SS-ENLST
你试试在插入块后加入:
还是不行,我觉得是提前中断了,我整理下发上,问题应该是出在 sldomov 的前面部分
 楼主| 发表于 2020-3-10 22:56:31 | 显示全部楼层
少 SS-ENLST
你试试在插入块后加入:
又丢了
GMT+8, 2025-5-15 11:06 , Processed in 0.170721 second(s), 29 queries , Gzip On.
