查看: 671|回复: 2
[提问] 各位老师,我想批量生成折线的外框,运行时部分图纸外框范围有误,求指点
发表于 2020-3-21 11:36:55 | 显示全部楼层 |阅读模式
发表于 2020-3-21 15:08:20 | 显示全部楼层
(defun C:test ()
  (vl-load-com)
  (command "undo" "be")
  (setvar "cmdecho" 0)
  (setvar "osmode" 0)
  (command "ucs" "w")
  (princ "\n请选择折线:")
  (while (null
           (setq EN
             (ssget
               '((70 . 0)
                 (90 . 3)
                 (0 . "LWPOLYLINE")
  (setq i 0)
  (while (setq ee (ssname en i))
    (apply
     'vl-cmdf (cons ".Rectangle" (acet-ent-geomextents ee))
    ;; (vl-cmdf)
    (setq i (1+ i))
  (vl-cmdf "undo" "e")
  (setvar "osmode" 16383)
 楼主| 发表于 2020-3-21 15:19:15 | 显示全部楼层
可以啦,谢谢Andyhon老师的指导
GMT+8, 2025-7-16 03:46 , Processed in 0.169023 second(s), 26 queries , Gzip On.
