查看: 2546|回复: 11
[提问] lisp实现排序
发表于 2020-3-25 15:43:41 | 显示全部楼层 |阅读模式
本人不会用lisp程序排序,排序后最终效果如图纸中右侧所示,望各路高手赐教!
看下六楼,就是我说的那几个函数配合  发表于 2020-3-26 11:20
发表于 2020-3-25 18:11:40 | 显示全部楼层
支持一下,以前好像有人发过出来的,你在论坛上找找。
发表于 2020-3-25 18:17:13 来自手机 | 显示全部楼层
vl-sort 先<y后<x,排序后表配合vl-remove-if和vl-remove-ifnot即可
 楼主| 发表于 2020-3-26 08:42:36 | 显示全部楼层
对这几个函数我还不是很清楚,这是我写的排序程序,但是实现不了我所想要的功能,麻烦您给看看
(defun c:zdx2()
  (setvar "cmdecho" 0)
  (setq osm(getvar "osmode"))
  (setvar "osmode" 0)
  (if (tblsearch "layer" "bhc")
             (command "layer" "s" "bhc" "")
             (command "layer" "n" "bhc" "c" "4" "bhc" "s" "bhc" "")
  (princ "\n 请选择需要编号的圆:")
  (setq ss (ssget '((0 . "circle"))));过滤选择圆zdx
  (setq sn (if ss (sslength ss) 0));设sn为选择集的个数
  (setq ns 0 )
  (setq a1(getstring "\n加前缀<P>:"))
  (if (= a1 "")(setq a1 "P"))          ;假若参数是字符,回车空格键都是空值,不是nil
  (setq a2(getint"\n请输入起始数值<1>:"))
  (if (= a2 nil)(setq a2 1))     ;假若参数为数值,回车等于nil
  (setq ss2 '())
   (while (and (< ns sn) ss)   ;and表示后面两个参数都有值,否则输出nil
          (setq a(rtos a2 2 0))
          (setq aa(strcat a1 a))
          (setq ssg (entget (ssname ss ns))  ;逐一获取选择集中的图元信息
                  yx(assoc 10 ssg)        ;求出圆心
                 ss2(cons (cdr yx) ss2)
                  r (cdr (assoc 40 ssg))  ;返回半径
                  y(cadr yx)              ;求出文字Y坐标
                  x(-(caddr yx)(* 1.8 r)) ;求出文字x坐标
                     ns (1+ ns)
     ;;以下排序输出,还需改进,不能按y值排列
                     (setq ss3(vl-sort ss2
                                  (function
                                    (lambda (x y)
;;;                                            (< (car x) (car y))
                                              (< (cadr x) (cadr y))
                     (setq ss2-yx(car ss3))
                 (command "text" "j" "Mc"  ss2-yx (* 1.4 r) "0" aa);标注文字
                 (setq a2 (1+ a2))    ;数值累加
  (command "undo" "e")
  (setvar "osmode" osm)
(prompt "****【c:zdx2】****")
发表于 2020-3-26 09:58:25 | 显示全部楼层
  1. (defun c:tt(  / ss lst ent ls out i )
  2. (setq ss (ssget (list '(0 . "Circle"))))
  3. (setq ls nil)
  4. (while (> (sslength ss) 0)
  5. (setq ent (ssname ss 0))
  6. (setq ss (ssdel ent ss))
  7. (setq ls (cons (cdr (assoc 10 (entget ent))) ls))
  8.   )
  9. (setq out
  10. (vl-sort ls '(lambda (a b)
  11.                             (if
  12.                              (equal (cadr a) (cadr b) 0.1 )
  13.                              (< (car a) (car b))
  14.                              (< (cadr a) (cadr b))
  15.                              )
  16.                             )
  17.                          )
  18.       )
  19. (setq i 0)
  20. (foreach e out
  21. (entmake
  22.       (list '(0 . "TEXT")
  23.       (cons 10 e)
  24.       (cons 40  450)
  25.       (cons 1 (itoa i))
  26.       )
  27.     )
  28.   (setq i (+ 1 i))
  29. )
  30. )
试一哈哇
发表于 2020-3-26 11:10:52 | 显示全部楼层
(defun c ...
根据您的稍微改了一下
 楼主| 发表于 2020-3-26 15:10:51 | 显示全部楼层
x_s_s_1 发表于 2020-3-26 11:10
根据您的稍微改了一下
非常感谢,你的程序非常完美!
 楼主| 发表于 2020-3-26 15:12:28 | 显示全部楼层
谢谢了,但是您的这个程序只实现了数字编号,没有排号
发表于 2020-3-26 15:16:13 | 显示全部楼层
改下就可以,思路是那样的
发表于 2020-3-27 21:28:53 | 显示全部楼层
打开你的图是空白的
(setq lst '((1 1) (1 2) (1 3) (2 1) (2 2) (2 3)))
(vl-sort lst '(lambda (e1 e2)(if (equal (cadr e1) (cadr e2) 1)(< (car e1) (car e2))
(< (cadr e2) (cadr e1)))))
返回结果:((1 3) (2 3) (1 2) (2 2) (1 1) (2 1))
GMT+8, 2025-5-18 05:45 , Processed in 0.192629 second(s), 30 queries , Gzip On.
