查看: 1229|回复: 10
[源码] 请求修改
发表于 2020-4-1 23:39:59 | 显示全部楼层 |阅读模式
100明经币
如果改变颜色的对象要自己选择,要修改哪里呢?
以下是所有的图都改颜色了。
(defun c:resetcolor (/ c)
  (setq c  8 )
  (if c
    (vlax-for block (vla-get-blocks
                      (vla-get-activedocument (vlax-get-acad-object))
      (vlax-for        ent block
        (vl-catch-all-apply 'vla-put-color (list ent c))
        ;; 增加对参照中属性的处理
        (if (and (= "AcDbBlockReference" (vla-get-objectname ent))
                 (= :vlax-true (vla-get-hasattributes ent))
          (foreach att (vlax-safearray->list
                         (vlax-variant-value (vla-getattributes ent))
            (vla-put-color att c)
最佳答案
查看完整内容
;或者 (defun c:resetcolor (/ c) (setq cmd (getvar "cmdecho")) (setvar "cmdecho" 0) (setq Document (vla-get-ActiveDocument (vlax-get-acad-object))) (setq Blocks (vla-get-blocks Document)) (vla-StartUndoMark Document) (setq c 8 ) (If (progn (princ "\n请选择要更改颜色的图元:") (setq ssa (ssget)) ) (vlax-for Obj (vla-get-ActiveSelectionSet Docume ...
发表于 2020-4-1 23:40:00 | 显示全部楼层
;或者
  (setq c  8 )
  (If (progn
          (setq ssa (ssget))
      (vlax-for Obj (vla-get-ActiveSelectionSet Document)
         (vl-catch-all-apply 'vla-put-color (list Obj c))
         (if (= "AcDbBlockReference" (vla-get-objectname Obj))
                 (vlax-for BlkObj (vla-item Blocks (vla-get-name Obj))
                       (vl-catch-all-apply 'vla-put-color (list BlkObj c))
                 (if (= :vlax-true (vla-get-hasattributes Obj))
                     (foreach AttObj (vlax-safearray->list
                                           (vlax-variant-value (vla-getattributes Obj))
                         (vl-catch-all-apply 'vla-put-color (list AttObj c))
  (vla-EndUndoMark Document)
  (vlax-release-object Blocks)
  (vlax-release-object Document)
  (setvar "cmdecho" cmd)
发表于 2020-4-2 01:47:39 | 显示全部楼层
(DEFUN C:c1 (/ pnam)
  (if (setq pnam (ssget))
    (COMMAND "chprop" pnam "" "c" "1" "")
  (PRINC)
以此类推
发表于 2020-4-2 07:01:04 | 显示全部楼层
改第一行  (setq c  8 )   改成  (setq c (getint "\n 输入颜色值: "))
 楼主| 发表于 2020-4-2 07:47:06 | 显示全部楼层
您好!
不用输入颜色值的
想要的是自己选择对象去修改颜色,不是把整个图的对象都改变颜色.
是不是各这个有关?   vl-catch-all-apply
发表于 2020-4-2 09:14:45 | 显示全部楼层
  (setq c  8 )
  (If (progn
          (setq ssa (ssget))
         (if (and (= "AcDbBlockReference" (vla-get-objectname Obj))
Command: v8 选择要修改颜色的对象: Select objects: 1 found Select objects: ; error: Automation Error. Calling method AddItems of interface IAcadSelectionSet failed  发表于 2020-7-16 23:57
大师!使用了一段时间了 有个问题,偶尔在用的时候就不能改颜色了,信息如下 Command: v8 选择要修改颜色的对象: Select objects: 1 found Select objects: ; error: Automation Error. Calling method AddItem   发表于 2020-7-16 23:56
发表于 2020-4-2 09:45:21 | 显示全部楼层
;;選擇一对象改變顏色
(defun c:ch1 (/ c)
  (setq c 3 )  ;指定顏色 綠色
  (setq en (car (entsel)))
  (command "chprop" en "" "c" c )
发表于 2020-4-2 11:02:05 | 显示全部楼层
(defun c:tt (/ c en i ins names ojb ss)
  (setq c  8 )
        (setq ss(ssget))
        (setq i -1 names nil)
        (while (setq en(ssname ss(setq i(1+ i))))
                (setq ojb (vlax-ename->vla-object en))
                (if(/= (cdr (assoc 0 (entget en )))"INSERT")
                        (vla-put-color ojb c)
                                (setq ins(cdr (assoc 2 (entget en ))))
                                (if(member ins names)nil(setq names(cons ins names)))
                                (if (= :vlax-true (vla-get-hasattributes ojb))
                         (vlax-variant-value (vla-getattributes ojb))
                (if(member (vlax-get-property block 'Name)names)
                        (vlax-for ent block
 楼主| 发表于 2020-4-2 23:12:49 | 显示全部楼层
yshf 发表于 2020-4-2 09:24
;或者
可以了!非常感谢!
GMT+8, 2025-5-18 07:33 , Processed in 0.928141 second(s), 25 queries , Gzip On.
