查看: 551|回复: 1
[提问] 各位大神,我这个三维设备求重心的命令为什么有时候行,有时候显示错误?
发表于 2020-4-8 14:22:31 | 显示全部楼层 |阅读模式
(defun c:zhongxin()
  (vl-load-com)
  (alert "请选择所有的三维实体")
  (setq ss (ssget '((0 . "3Dsolid"))))
  (command "_union"ss "")
  (setq pt (vlax-safearray->list (vlax-variant-value (vla-get-centroid (vlax-ename->vla-object (entlast))))))
  (command "point" pt )
  (command "circle" pt 500 )
GMT+8, 2025-5-18 07:39 , Processed in 0.155495 second(s), 24 queries , Gzip On.
