查看: 3677|回复: 13
[提问] 修改一个批量改块内填充类型的工具
发表于 2020-4-13 14:00:11 | 显示全部楼层 |阅读模式
5明经币
恳请各位大师修改一个批量改块内填充图案的工具,将不同块内的同一个填充,改为我需要的填充
以下是G版的代码(感谢Gu_xl版主),但是我不知道如何使用,恳请各位给予帮助,非常感谢!!
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=109395&highlight=%BF%E9
  • (defun f (n a b / doc blkdef)
  •   (if (not
  •         (VL-CATCH-ALL-ERROR-P
  •           (setq        blkdef
  •                  (VL-CATCH-ALL-APPLY
  •                    'vla-item
  •                    (list
  •                      (vla-get-blocks
  •                        (setq doc
  •                               (vla-get-ActiveDocument
  •                                 (vlax-get-acad-object)
  •                      n
  •     (progn
  •       (vlax-for        o blkdef
  •         (if (and
  •               (= "AcDbHatch" (vla-get-ObjectName o))
  •               (= (strcase a) (strcase (vla-get-PatternName o)))
  •             'vla-SetPattern
  •             (list o
  •                   (vla-get-PatternType o)
  •                   b
  •       (vla-regen doc :vlax-true)
最佳答案
发表于 2020-4-13 14:00:12 | 显示全部楼层
Sonnenblumen 发表于 2020-4-13 17:49
非常感谢您,程序很好用,但是有个问题,如果我要改多种图案,就需要在代码里一次次的改填充图案名称,这 ...
  1. (defun c:tt (/ ss i ii blk blkname pattern1 pattern2 ly keyword namelist)  (princ "\n >>>>>1-请选择块参照...")
  2.   (setq ss (ssget '((0 . "INSERT"))))
  3.   (princ "\n >>>>>2-请选择原填充图案...")
  4.   (setq pattern1 (cdr (assoc 2 (entget (car (nentselp))))))
  5.   (princ "\n >>>>>3-请选择新填充图案...")
  6.   (setq pattern2 (car (nentselp)))
  7.   (setq ly (cdr (assoc 8 (entget pattern2))))
  8.   (setq pattern2 (cdr (assoc 2 (entget pattern2))))
  9.   (initget "1 2")
  10.   (setq keyword (getkword "\n是否同时更改图层?[<1>改/<2>不改]:"))
  11.   (setq i 0)
  12.   (repeat (sslength ss)
  13.     (setq blk (ssname ss i))
  14.     (setq blkname (cdr (assoc 2 (entget blk))))
  15.     (f blkname pattern1 pattern2 keyword ly)
  16.     (GetBlkNameInBLK blk)
  17.     (setq namelist (delsame namelist))
  18.     (setq ii 0)
  19.     (repeat (length namelist)
  20.       (setq blkname (nth ii namelist))
  21.       (f blkname pattern1 pattern2 keyword ly)
  22.       (setq ii (1+ ii))
  23.     )
  24.     (entupd blk);;刷新图元显示
  25.     (setq i (1+ i))
  26.   )
  27.   ;(command "regen")
  28.   (princ)
  29. )
  30. (defun f (n a b c d / doc blkdef)
  31.   (if (not
  32.         (VL-CATCH-ALL-ERROR-P
  33.           (setq        blkdef
  34.                  (VL-CATCH-ALL-APPLY
  35.                    'vla-item
  36.                    (list
  37.                      (vla-get-blocks
  38.                        (setq doc
  39.                               (vla-get-ActiveDocument
  40.                                 (vlax-get-acad-object)
  41.                               )
  42.                        )
  43.                      )
  44.                      n
  45.                    )
  46.                  )
  47.           )
  48.         )
  49.       )
  50.     (vlax-for o        blkdef
  51.       (if (and
  52.             (= "AcDbHatch" (vla-get-ObjectName o))
  53.             (= (strcase a) (strcase (vla-get-PatternName o)))
  54.           )
  55.         (progn
  56.           (VL-CATCH-ALL-APPLY
  57.             'vla-SetPattern
  58.             (list o
  59.                   (vla-get-PatternType o)
  60.                   b
  61.             )
  62.           )
  63.           (if (= c "1")
  64.             (VL-CATCH-ALL-APPLY 'vla-put-layer (list o d))
  65.           )
  66.         )
  67.       )
  68.     )
  69.   )
  70. )
  71. (defun GetBlkNameInBLK
  72.                        (BlkEntName / xBlkName xBlkDef entName1 entType
  73.                         blkname)
  74.   (setq xBlkName (cdr (assoc 2 (entget BlkEntName))))
  75.   (setq xBlkDef (tblobjname "Block" xBlkName))
  76.   (while (setq entName1 (entnext xBlkDef))
  77.     (setq entType (cdr (assoc 0 (entget entName1))))
  78.     (if        (= entType "INSERT")
  79.       (progn
  80.         (setq blkname (vla-get-effectivename
  81.                         (vlax-ename->vla-object entName1)
  82.                       )
  83.         )
  84.         (setq namelist (cons blkname namelist))
  85.         (GetBlkNameInBLK entName1)
  86.       )
  87.     )
  88.     (setq xBlkDef entName1)
  89.   )
  90. )
  91. (defun delsame (l)
  92.   (if l
  93.     (cons (car l)
  94.           (delsame (vl-remove (car l) (cdr l)))
  95.     )
  96.   )
  97. )
参与人数 1金钱 +20 收起 理由
Sonnenblumen + 20 大师程序很好用!!
发表于 2020-4-13 16:47:29 | 显示全部楼层
(f n a b)
(f "块名称" "修改前填充图案名称" "修改后填充图案名称")
(defun c:tt (/ ss i blk pattern1 pattern2)
  (setq pattern1 "ANSI31");;修改前填充图案名称
  (setq pattern2 "ANSI37");;修改后填充图案名称
  (setq i 0)
    (setq blk(ssname ss i))
    (setq blk(cdr (assoc 2 (entget blk))));;块名称
    (f blk pattern1 pattern2);;调用子程序
    (setq i (1+ i))
  (command "regen")
  (if (not
          (setq        blkdef
                 (VL-CATCH-ALL-APPLY
                   'vla-item
                   (list
                     (vla-get-blocks
                       (setq doc
                     n
      (vlax-for        o blkdef
        (if (and
          (VL-CATCH-ALL-APPLY
            'vla-SetPattern
            (list o
                  b
      ;(vla-regen doc :vlax-true);;刷新,建议在主程序中刷新以提高速度
复制代码
 楼主| 发表于 2020-4-13 17:08:30 | 显示全部楼层
gaics 发表于 2020-4-13 16:47
(f n a b)
感谢您的回帖,我还是没看明白,能麻烦您帮改一下代码吗?
发表于 2020-4-13 17:28:14 | 显示全部楼层
已改。
修改块参照后需要刷新,gu版是在子程序内刷新,批量操作的话影响速度,建议在主程序中刷新。
 楼主| 发表于 2020-4-13 17:49:27 | 显示全部楼层
gaics 发表于 2020-4-13 17:28
已改。
非常感谢您,程序很好用,但是有个问题,如果我要改多种图案,就需要在代码里一次次的改填充图案名称,这样效率会很低,可以实现点选源图案,再点选要替换的图案,再框选要替换的块这样的功能么?
发表于 2020-4-14 08:54:03 | 显示全部楼层
以下为搬运,可以全图改。
这个是改具体的。
相关讨论:
https://www.cadtutor.net/forum/topic/63658-change-solid-hatch/
 楼主| 发表于 2020-4-14 09:46:08 | 显示全部楼层
感谢您的回复,感谢您的代码,非常好用,达到了我的预期,感谢感谢
我还想问您一下,这个是否可以实现,替换的时候给一个选择,被替换的图案是否要跟随源图案图层,这样的功能。您的代码可以替换图案样式,但是不能替换图层,恳请您帮助。
 楼主| 发表于 2020-4-14 09:47:03 | 显示全部楼层
panliang9 发表于 2020-4-14 08:54
以下为搬运,可以全图改。
这个是改具体的。
感谢您的回复,谢谢
 楼主| 发表于 2020-4-14 10:24:23 | 显示全部楼层
请问大师,如果是嵌套块,这样的替换功能如何实现呢?
GMT+8, 2025-5-18 05:58 , Processed in 0.210311 second(s), 27 queries , Gzip On.
