查看: 789|回复: 4
[提问] 递增复制如何避免A01 变A2?
发表于 2020-4-15 16:56:35 | 显示全部楼层 |阅读模式
下面是论坛上的递增复制 原作者忘了是谁了  如何修改让递增复制时避免A01变A2?
  1. ;;递增复制
  2. (defun C:tt (/ en pt1 ptnext eny ss ssx eno)
  3.   (princ "\n选择要复制的文字")
  4.   (setq ss (ssget '((0 . "*TEXT"))))
  5.   (setq pt1 (getpoint "\n指定复制角点"))
  6.   (setq ptnext (getpoint pt1 "\n指定插入点"))
  7.   (while ptnext
  8.     (setq eno (entlast) ssx (ssadd))
  9.     (command ".copy" ss "" "m" pt1 ptnext "")
  10.     (while (setq en (entnext eno)) (setq ssx (ssadd en ssx) eno en))
  11.     (setq n 0)
  12.     (repeat (sslength ssx)
  13.       (setq en (ssname ssx n))
  14.       (setq eny (ttg (vla-get-textstring (Vlax-Ename->Vla-Object en))))
  15.       (Vlax-Put-Property (Vlax-Ename->Vla-Object en) 'TextString eny)
  16.       (setq n (1+ n))
  17.     );end repeat
  18.     (setq ss ssx)
  19.     (setq pt1 ptnext)
  20.     (setq ptnext (getpoint pt1  "\n指定插入点"))
  21.   )
  22.   (princ "\n**********完成操作************")
  23.   (prin1)
  24. );end
  25. (prin1)
  26. (defun ttg (txd / tth tthh )
  27.   (setq tth (ttm txd) tthh (rtos (1+ tth) 2 0))
  28.   (setq regex (vlax-create-object "Vbscript.RegExp")) ;引用正则表达式控件
  29.   (vlax-put-property regex "IgnoreCase" 0) ;不忽略大小写
  30.   (vlax-put-property regex "Global" 1) ;匹配方式,全文字匹配
  31.   (vlax-put-property regex "Multiline" 1) ;多行模式
  32.   txd
  33.   (vlax-put-property regex "Pattern" "[0-9]+(?=[^0-9]*$)")
  34.   (setq enX (vlax-invoke-method  regex "Replace" txd tthh))
  35.   (vlax-release-object regex)
  36.   enx
  37. )
  38. (prin1)
  39. ;取得文字
  40. (defun ttq (x / )
  41.   (setq xs (vla-get-TextString (vlax-ename->vla-object x)))
  42. )
  43. (prin1)
  44. ;提取出字符串中的数字,是直接从字串里面得到数值
  45. (defun ttm (en / regex S tmp str1)
  46.   (setq regex (vlax-create-object "Vbscript.RegExp")) ;引用正则表达式控件
  47.   (vlax-put-property regex "IgnoreCase" 0) ;不忽略大小写
  48.   (vlax-put-property regex "Global" 1) ;匹配方式,全文字匹配
  49.   (vlax-put-property regex "Multiline" 1) ;多行模式
  50.   (vlax-put-property regex "Pattern" "[0-9]+(?=[^0-9]*$)")
  51.   (setq s (vlax-invoke-method regex "Execute" en))
  52.   ;;将规则运用到STR字符,得到提取出的文字内容
  53.   (setq ent (VLAX-FOR tmp s (vlax-get-property tmp "value")))
  54.   (vlax-release-object regex)
  55.   (setq ent (atoi ent))
  56.   ent
  57. )
  58. (prin1)
发表于 2020-4-15 20:18:42 | 显示全部楼层
发表于 2020-4-16 07:27:14 | 显示全部楼层
 楼主| 发表于 2020-4-16 08:39:05 | 显示全部楼层
Andyhon 发表于 2020-4-15 20:18
http://gyh060707.blog.sohu.com/153977613.html
谢谢
 楼主| 发表于 2020-4-16 08:39:28 | 显示全部楼层
xj6019 发表于 2020-4-16 07:27
http://bbs.mjtd.com/thread-181181-1-1.html
  谢谢
GMT+8, 2025-5-18 06:00 , Processed in 0.184207 second(s), 25 queries , Gzip On.
