查看: 883|回复: 2
[提问] 怎么获取矩形多线段的坐标点?
发表于 2020-4-18 15:26:46 | 显示全部楼层 |阅读模式
我想在A4打印框里添加全图的水印,防止被复印,但是不知道怎么添加文字,大概就像下图A4框3X6的水印,A3就是旋转90°放大的A4
  1. (defun c:addtk()
  2.       (setvar "cmdecho" 0)
  3.       (princ "选择要添加的矩形图框:")
  4.       (setq ss (ssget))
  5.       (setq rate (getreal "\n输入公司名称:"))
  6.       (if (= rate nil) (princ "公司名不能为空")
  7.       (setq n 0)
  8.       (repeat (sslength ss)
  9.             (setq ent (ssname ss n))
  10.             (setq ent_data (entget ent))
  11.             (setq ent_type (cdr (assoc 0 ent_data)))
  12.                 (setq ent_tuc (cdr (assoc 8 ent_data)))
  13.             (if (= ent_type "LWPOLYLINE")
  14.                 (if (= ent_tuc "打印框")
  15.                  (if (= (cdr (assoc 70 ent_data)) 1)
  16.
  17.                   ;
  18.
  19.                 )
  20.                 )
  21.                 )
  22.             (setq n (1+ n))
  23.             )
  24.       (princ)
  25.       )
发表于 2020-4-23 14:34:49 | 显示全部楼层
获取矩形多段线的四个顶点坐标
(setq ptlist (Vlax-Get (Vlax-Ename->Vla-Object (car (entsel))) 'Coordinates )
       pt1 (list (car ptlist) (cadr ptlist))
       pt2 (list (caddr ptlist) (nth 3 ptlist))
       pt3 (list (nth 4 ptlist) (nth 5 ptlist))
       pt4 (list (nth 6 ptlist) (nth 7 ptlist))
GMT+8, 2025-5-18 05:26 , Processed in 0.162727 second(s), 26 queries , Gzip On.
