查看: 4843|回复: 16
[提问] 求程序-快速做快并拾取文字为块名
发表于 2020-5-9 16:10:16 | 显示全部楼层 |阅读模式
10明经币
10币求个偷懒小程序,程序过程如下:
选取图元,输入命令,空格,拾取文字为块名,空格,选择基点同时完成块制作!
最佳答案
发表于 2020-5-9 16:10:17 | 显示全部楼层
cjjh8301 发表于 2020-5-12 11:17
有同名块没有提示就直接替换了,我是想,出现同名块,就提示下有同名块,然后有(N/Y)选择是否替换,默认 ...
  1. (defun c:tt (/ p ss str doins)
  2.   (setvar 'cmdecho 0)
  3.   (if (and (setq ss (ssget))
  4.            (setq str (car (entsel "选择块名文字对象:")))
  5.            (setq p (getpoint "指定基点:"))
  6.       )
  7.     (progn
  8.       (setq str          (cdr (assoc 1 (entget str)))
  9.             doins "Y"
  10.       )
  11.       (if (vl-catch-all-error-p
  12.             (vl-catch-all-apply
  13.               'vla-item
  14.               (list (vla-get-blocks
  15.                       (vla-get-activedocument (vlax-get-acad-object))
  16.                     )
  17.                     str
  18.               )
  19.             )
  20.           )
  21.         (command ".block" str p ss "")
  22.         (progn
  23.           (initget "Y N")
  24.           (setq doins (getkword "是否替换同名块[是(Y)/否(N)]:"))
  25.           (if (= "Y" doins)
  26.             (command ".block" str "Y" p ss "")
  27.           )
  28.         )
  29.       )
  30.       (if (= "Y" doins)
  31.         (command ".insert" str p 1. 1. 0.)
  32.       )
  33.     )
  34.   )
  35.   (setvar 'cmdecho 1)
  36. )
发表于 2020-5-9 23:42:52 | 显示全部楼层
  1. (defun c:tt (/ p ss str)
  6.       )
  7.     (progn
  8.       (setq str (cdr (assoc 1 (entget str))))
  9.       (command ".block" str p ss "")
  10.       (command ".insert" str p 1. 1. 0.)
  11.     )
  12.   )
  13.   (setvar 'cmdecho 1)
  14. )
发表于 2020-5-10 09:44:52 | 显示全部楼层
(defun c:tt (/ p ss ssbox str)   ;已加入块基点
  (setvar 'cmdecho 0)
  (if (and
                             (setq ssbox (zg-GetSSBoundingbox (setq ss (ssget))))
           (setq str (car (entsel "\n选择块名文字对象:")))
                        (setq p (apply 'mapcar (cons (function (lambda (a b) (/ (+ a b) 2))) ssbox))))
      (command ".insert" str p 1. 1. 0.)))
  (setvar 'cmdecho 1))
;块基点为选择集中心点  原作者:namezg
(defun zg-GetSSBoundingbox (ss / i ssn ll rr box ptlist ssbox)
                (if ss
                                (setq i -1)
                                (repeat (sslength ss)
                                        (setq ssn (ssname ss (setq i (1+ i))))
                                        (vla-GetBoundingBox (vlax-ename->vla-object ssn) 'll 'rr)  ;得到对象的包围盒
                                        (setq box (list (vlax-safearray->list ll) (vlax-safearray->list rr)))
                                        (setq ptlist (append box ptlist)))
                                (setq ssbox (mapcar '(lambda (x) (apply 'mapcar (cons x ptlist))) (list 'min 'max))))))
 楼主| 发表于 2020-5-10 22:44:30 | 显示全部楼层
可以用,但是我我忽略了一个问题,就是有同名块时,能否提示有同名块,然后可以选择N/Y,
N不替换程序结束;Y替换同名块,结束程序,(默认N)
发表于 2020-5-11 17:22:58 | 显示全部楼层
N不替换程序结 ...
  (setvar 'cmdecho 0)
      (if (vla-item (vla-get-blocks
                    str
  (setvar 'cmdecho 1)
 楼主| 发表于 2020-5-12 08:59:17 | 显示全部楼层
  (setvar 'cmdecho 0)
选择基点后没有成块,麻烦看下,是什么问题!!!
发表于 2020-5-12 09:58:08 | 显示全部楼层
  6.       )
  7.     (progn
  9.       (if (vl-catch-all-error-p
  10.             (vl-catch-all-apply
  11.               'vla-item
  12.               (list (vla-get-blocks
  13.                       (vla-get-activedocument (vlax-get-acad-object))
  14.                     )
  15.                     str
  16.               )
  17.             )
  18.           )
  19.         (command ".block" str p ss "")
  20.         (command ".block" str "Y" p ss "")
  21.       )
  22.       (command ".insert" str p 1. 1. 0.)
  23.     )
  24.   )
  25.   (setvar 'cmdecho 1)
  26. )
 楼主| 发表于 2020-5-12 11:17:14 | 显示全部楼层
有同名块没有提示就直接替换了,我是想,出现同名块,就提示下有同名块,然后有(N/Y)选择是否替换,默认为不替换,帮我再修改下
 楼主| 发表于 2020-5-12 16:58:03 | 显示全部楼层
  (setvar 'cmdecho 0)
  (if (and
同时感谢这位兄弟!
GMT+8, 2025-11-14 04:04 , Processed in 0.175840 second(s), 25 queries , Gzip On.
