如下代码可以把所有图快变成8号色,但是把图层全部设置成了dxt图层,请问如何不改变原始图层 - (Defun c:t2 (/ ss ss1 ss2 n ex ext color layer i colot layer)
- ;; 主程序
- (vl-load-com)
- (setq color 8 layer "dxt")
- (if (=(tblsearch "layer" layer)nil)(progn
- (command "layer" "N" layer "c" color layer "")));;如果没有dxt层就创建新的dxt层
- (princ "\n选要变更颜色的图形: ")
- (setq ss(ssget))
- (setq n (sslength ss))
- (setq i 0)
- (setq ss1(ssadd))
- (setq ss2(ssadd))
- (while (< i n)
- (setq ex (ssname ss i))
- (setq ext (cdr(assoc 0 (entget ex))))
- (if (= ext "INSERT") (progn (setq ss1(ssadd ex ss1))));;创建一个新的选集,只包含图块
- (if (/= ext "INSERT") (progn (setq ss2(ssadd ex ss2))));;创建一个新的选集,包含除了块以外的所有图形
- (setq i(+ i 1)))
- (sub_block ss1)
- (sub_xxx ss2 layer color)
- (princ)
- ;;子程序1
- (defun sub_xxx(ss2 layer color / nxt et i n2)
- (setq n2 (sslength ss2))
- (setq i 0)
- (while (< i n2)
- (setq et (ssname ss2 i))
- (setq nxt(entget et))
- (setq nxt (subst (cons 8 layer)(assoc 8 nxt) nxt ));;变更图层
- (setq nxt (subst (cons 62 256)(assoc 62 nxt) nxt ));;改变颜色随层
- (entmod nxt)
- (setq i(+ i 1))))
- ;;子程序2
- (defun sub_block(ss1 / i bolcks vn n1 )
- (setq n1 (sslength ss1))
- ;;; (setq ss1 (vl-catch-all-apply 'ssget '(((0 . "INSERT")))))
- ;;; (cond ((or (vl-catch-all-error-p ss1) (null ss1)) (vl-exit-with-value 0)))
- (setq i 0
- *AcadDocument* (vla-get-activeDocument (vlax-get-acad-object))
- blocks (vla-get-blocks *AcadDocument*)
- (repeat n1
- (setq vn (vlax-ename->vla-object (ssname ss1 i))
- i (1+ i))
- ;; 防止出错 .
- (sub_Fun vn)
- (prin1)
- ;; 子程序2-1
- (Defun sub_Fun (vn)
- (vla-put-color vn color)
- (vla-put-layer vn layer)
- (vlax-for ent (vla-item blocks (vla-get-name vn))
- (vla-put-color ent color)
- (vla-put-layer ent layer)
- (if (= (vla-get-objectname ent) "AcDbBlockReference")
- (sub_Fun ent)
代码来源于本论坛,附件内容一样 |
