查看: 3191|回复: 11
[源码] 旧图块替换为指定图块
发表于 2020-6-11 15:05:33 | 显示全部楼层 |阅读模式
  • ;;旧图块替换为指定图块
  • ;;可实现自动匹配图块旋转角(要求源图块的插入点在旋转中心)
  • (defun C:BTOB (/ *error*_bak *error*_sh ang ang1 anglst angn blk1 blk2 blk2name data dist lst n name orth os pisrt pon pt1 pt2 ptanglst ptlst ptn ss yn)
  •   (defun *error*_sh (msg)
  •     (setq *error* *error*_bak)
  •     (setvar "osmode" os)
  •     (setvar "orthomode" orth)
  •     ;(command "undo" "e")
  •   (command "undo" "be")
  •   (setq *error*_bak *error*)
  •   (setq *error* *error*_sh)
  •   (setvar "cmdecho" 0)
  •   (setq os (getvar "osmode"))
  •   (setq orth (getvar "orthomode"))
  •   (setq lst '())
  •   (setq n 0)
  •   (if (setq blk1 (car (entsel "\n选择源图块")))
  •     (if (and (= "INSERT" (cdr (assoc 0 (entget blk1)))) (setq pt1 (getpoint "\n指定源图块基点")));源图块及基点设定
  •       (if (setq blk2 (car (entsel "\n选择一个被替换的块")))
  •         (if (and (= "INSERT" (cdr (assoc 0 (entget blk2)))) (setq pt2 (getpoint "\n指定被替换对象块的基点")));被替换块及基点设定
  •           (progn
  •             (setq blk2name (cdr (assoc 2 (entget blk2))))
  •             (setq pisrt (cdr (assoc 10 (entget blk2))))
  •             (setq dist (distance pisrt pt2))
  •             (setq ang (angle pisrt pt2))
  •             (setq ang1 (cdr (assoc 50 (entget blk2))));;以块的插入点及指定的点相对关系,确定每个将要被替换的块(以复制后删除方式实现替换)的复制第二点
  •             (if (setq ss (ssget (list (cons 0 "INSERT") (cons 2 blk2name))))
  •               (progn
  •                 (setq ptlst '() anglst '())
  •                 (repeat (sslength ss)
  •                   (setq name (ssname ss n))
  •                   (setq ptn (cdr (assoc 10 (entget name))))
  •                   (setq angn (cdr (assoc 50 (entget name))))
  •                   (setq pon (polar ptn (+ ang (- angn ang1)) dist))
  •                   (setq ptlst (cons pon ptlst))
  •                   (setq anglst (cons angn anglst))
  •                   (setq n (1+ n))
  •                 (setq ptanglst (mapcar 'list ptlst anglst));;每个被替换块的位置点+旋转角的列表
  •                 (setvar "orthomode" 0)
  •                 (setvar "osmode" 0)
  •                 (foreach x ptanglst
  •                   (command ".copy" blk1 "" pt1 (car x))
  •                   (setq data (entget (entlast)))
  •                   (entmod (setq data (subst (cons 50 (cadr x)) (assoc 50 data) data)));;要求原图块插入点与自身旋转中心重合
  •                 (princ (strcat "\n已替换" (itoa (sslength ss)) "个对象"))
  •                 (initget "Y N")
  •                 (setq yn (getkword "\n是否删除原对象[是(Y)/否(N)]:"))
  •                 (if (or (null yn) (= (strcat yn) "Y"))
  •                   (command "erase" ss "")
  •                 (command "undo" "e")
  •           (princ "\n无效的图块或基点")
  •   (setvar 'OSMODE os)
  •   (setvar 'ORTHOMODE orth)
  •   (princ)
 楼主| 发表于 2020-6-11 15:22:36 | 显示全部楼层
一个小问题,11行注释掉
发表于 2020-6-11 16:30:49 | 显示全部楼层
直接通过改组码2来替换
发表于 2021-4-4 18:00:02 | 显示全部楼层
感谢分享,又捡到宝了,CAD自带的不能指定替换的范围
之前其他程序又转不了角度 这个全解决了 连插入点问题都考虑了
 楼主| 发表于 2020-6-11 16:48:11 | 显示全部楼层
pzweng 发表于 2020-6-11 16:30
直接通过改组码2来替换
这个思路不错,不过不知道替换时位置能不能按需实现,空了试试
 楼主| 发表于 2020-6-11 16:51:11 | 显示全部楼层
直接通过改组码2来替换
块可以这样操作呢?不会出现重名块覆盖?
发表于 2020-6-11 16:51:49 | 显示全部楼层
不错的程序!!!
发表于 2020-6-11 17:15:01 | 显示全部楼层
木香 发表于 2020-6-11 16:51
块可以这样操作呢?不会出现重名块覆盖?
可以的,我就是这样做的
发表于 2020-6-12 19:14:56 | 显示全部楼层
直接修改组码2的值即可(动态块除外)。
发表于 2021-4-2 14:50:59 | 显示全部楼层
我一直在研究这个功能,但当x y 坐标为-1就会出问题,坐标和角度都要置换
GMT+8, 2025-5-14 05:33 , Processed in 0.146863 second(s), 27 queries , Gzip On.
