查看: 1735|回复: 2
CAD提取文字VBA,有错误
发表于 2020-7-22 14:48:10 | 显示全部楼层 |阅读模式
借用别人的源码,但是运行老是提示“  Set objText = objEntity”类型不匹配,自己找不到原因。还请高手帮忙看下,怎么修改能够好用。
一下是源码
'函数名:CreateSSet
'描述:接收选择图元,实现过滤
Public Function CreateSSet(ByVal SSetName As String) As AcadSelectionSet
    Dim SSet As AcadSelectionSet
    Dim i As Integer
    For i = 0 To ThisDrawing.SelectionSets.Count - 1
        Set SSet = ThisDrawing.SelectionSets.Item(i)
        If StrComp(SSet.Name, SSetName, vbTextCompare) = 0 Then
            SSet.Delete
            Exit For
        End If
    Next i
    Set CreateSSet = ThisDrawing.SelectionSets.Add(SSetName)
End Function
'函数名:GetTextInsertCoord
'描述:接收一组文本对象,返回一个数组,实现提取文本的字符串,插入点坐标及高程.
Public Function GetTextInsertCoord(ByVal ssget As Object)
    Set SSet = ssget
    SSet.Select acSelectionSetAll
    Dim lngCount As Long
    Dim arrText() As String
    Dim txtCount As Long
    Dim objEntity As AcadEntity
    txtCount = SSet.Count
    ReDim arrText(1 To txtCount, 1 To 4)
    Dim objText  As AcadText
     For Each objEntity In SSet
        lngCount = lngCount + 1
        arrText(lngCount, 1) = objEntity.TextString     '文本字符串值
        With objText
            arrText(lngCount, 2) = Format(.InsertionPoint(0), "0.000000")  'Y值坐标'
            arrText(lngCount, 3) = Format(.InsertionPoint(1), "0.000000")   'X值坐标'
            arrText(lngCount, 4) = Format(.InsertionPoint(2), "0.00")       '高程'
        End With
     Next objEntity
     GetTextInsertCoord = arrText
     Set objEntity = Nothing
     Set objText = Nothing
     Set SSet = Nothing
End Function
'函数名:Initialize_Excel
'描述:接收一个数组,实现将文本的字符串,插入点坐标及高程导入当前打开的EXCEL.
'当没有安装EXCEL时,程序将会出错.
Public Sub Initialize_Excel(ByRef arrText() As String)
    Dim xlsApp As Object
    Dim wb As Object
    Dim sht As Object
    Set xlsApp = CreateObject("Excel.Application")
    xlsApp.Visible = True
    Set wb = xlsApp.Workbooks.Add()
    Set sht = wb.Sheets("Sheet1")
    sht.Range("A1").Resize(UBound(arrText), 4) = arrText
    sht.Range("B1:C" & UBound(arrText)).NumberFormatLocal = "0.000000"
    sht.Range("D1:D" & UBound(arrText)).NumberFormatLocal = "0.00"
    sht.Range("A:D").EntireColumn.AutoFit
    wb.SaveAs ThisDrawing.Path & "\" & "提取文本坐标.xlsx"
    xlsApp.Quit
    Set sht = Nothing
    Set wb = Nothing
    Set xlsApp = Nothing
End Sub
Sub Main()
    Set SSet = CreateSSet("mySelectionSet")
    Dim ArrTextCoordinate() As String
    ArrTextCoordinate = GetTextInsertCoord(SSet)
    Call Initialize_Excel(ArrTextCoordinate)
    MsgBox "导入文本已经完成", , "提示"
    Set SSet = Nothing
End Sub
发表于 2020-7-22 19:17:36 | 显示全部楼层
SSet.Select acSelectionSetAll 这句是全选图形内所有图形对象,除非图里全是单行文本,否则肯定会出错,加个过滤应该就行了。
 楼主| 发表于 2020-7-23 14:23:42 | 显示全部楼层
sgwsssxm 发表于 2020-7-22 19:17
SSet.Select acSelectionSetAll 这句是全选图形内所有图形对象,除非图里全是单行文本,否则肯定会出错,加 ...
是的,原来图里有线条,线条删除就好了。谢谢啊,我再研究研究
GMT+8, 2025-5-23 04:22 , Processed in 0.151852 second(s), 23 queries , Gzip On.
