查看: 756|回复: 8
[提问] 各位大神看下 这个画线的程序 我想给他加上图层为 花坛名称如何弄
发表于 2020-7-30 09:24:26 | 显示全部楼层 |阅读模式
(defun c:60x(/ BAK_CECOLOR BAK_WIDTH P P0)
  (if (setq p0(getpoint "\n指定第一点: "))
      (setq bak_width(getvar "PLINEWID"))
      (setq bak_cecolor(getvar 'cecolor))
      (setvar 'cecolor "211")
      (setvar "PLINEWID" 60)
      (setvar "cmdecho" 0)
      (command "pline" p0)
      (while(setq p(getpoint p0 "\r指定下一点: "))
        (command p)
        (setq p0 p)
      (command "")
      (and bak_width (setvar "PLINEWID" bak_width))
      (and bak_cecolor (setvar 'cecolor bak_cecolor))
      (setvar "cmdecho" 1)
发表于 2020-7-30 12:07:45 | 显示全部楼层
(command "") 后面加  (command "change" (entlast) "" "p" "la" "花坛名称" "")
 楼主| 发表于 2020-7-30 14:24:27 | 显示全部楼层
你好我改了后好像不是图层的花坛线
 楼主| 发表于 2020-7-30 14:28:26 | 显示全部楼层
原来图层没有的 我希望画的时候新建图层
发表于 2020-7-30 15:26:11 | 显示全部楼层
  1. (defun c:60x(/ BAK_CECOLOR BAK_WIDTH P P0)
  2.   (if (setq p0(getpoint "\n指定第一点: "))
  3.     (progn
  4.       (setq bak_width(getvar "PLINEWID"))
  5.       (setq bak_cecolor(getvar 'cecolor))
  6.       (setvar 'cecolor "211")
  7.       (setvar "PLINEWID" 60)
  8.       (setvar "cmdecho" 0)
  9.       (command "pline" p0)
  10.       (while(setq p(getpoint p0 "\r指定下一点: "))
  11.         (command p)
  12.         (setq p0 p)
  13.                         )
  14.       (command "")
  15.       (and bak_width (setvar "PLINEWID" bak_width))
  16.       (and bak_cecolor (setvar 'cecolor bak_cecolor))
  17.                         (if (tblsearch "layer" "花坛名称") "" (command "layer" "New" "花坛名称" ""))
  18.                         (command "change" (entlast) "" "P" "la" "花坛名称" "")
  19.       (setvar "cmdecho" 1)
  20.                 )
  21.         )
  22.   (princ)
  23. )
 楼主| 发表于 2020-7-30 16:32:32 | 显示全部楼层
你好能不能把图层颜色设置为前面设置前来的线的颜色啊
发表于 2020-7-30 18:47:49 | 显示全部楼层
实在没看懂你在说什么
 楼主| 发表于 2020-7-31 08:37:42 | 显示全部楼层
Sonnenblumen 发表于 2020-7-30 18:47
实在没看懂你在说什么
你好前面不是把线颜色设置为211了,就是新建的这个画坛的图层的颜色也设置为211
发表于 2020-7-31 09:28:02 | 显示全部楼层
(command "layer" "New" "花坛名称" "C" "211" "花坛名称" "")
GMT+8, 2025-5-17 21:11 , Processed in 0.193502 second(s), 27 queries , Gzip On.
