查看: 885|回复: 3
[讨论] 在cad将代码粘贴到命令行批量画圆怎么不成功?
发表于 2020-8-5 10:38:24 | 显示全部楼层 |阅读模式
在cad命令行用这样的指令(command"circle" '( 54.3961 -760.5572) '50 "")(一次复制,粘贴到命令行)批量画圆,怎么不能成功?
(command"circle" '( 162.081 -745.0745) '50 "")
(command"circle" '( 266.4664 -714.4242) '50 "")
(command"circle" '( 365.4274 -669.2302) '50 "")
(command"circle" '( 456.9492 -610.4127) '50 "")
发表于 2020-8-5 11:18:08 | 显示全部楼层
(command"circle" '( 54.3961 -760.5572) '50)
(command"circle" '( 162.081 -745.0745) '50)
(command"circle" '( 266.4664 -714.4242) '50)
(command"circle" '( 365.4274 -669.2302) '50)
(command"circle" '( 456.9492 -610.4127) '50)
发表于 2020-8-5 11:19:03 | 显示全部楼层
(command"circle" '( 54.3961 -760.5572) '50 )
(command"circle" '( 162.081 -745.0745) '50 )
or
(command"circle" '( 54.3961 -760.5572) '50   "circle" '( 162.081 -745.0745) '50 )
 楼主| 发表于 2020-8-5 12:47:22 | 显示全部楼层
谢谢
两位老师
GMT+8, 2025-12-1 04:10 , Processed in 0.156851 second(s), 26 queries , Gzip On.
