查看: 1045|回复: 0
(求助)偏量偏移(07有用 2020没有用)
发表于 2020-8-16 11:00:01 | 显示全部楼层 |阅读模式
请教一下大神,以下代码,可以在07版本实现,但是2020里面它提示“指定要向内偏(N)外偏(W):N ; 错误: 参数类型错误: consp 0.0”  请问是怎么回事呢
请各位论坛大神解惑
框选偏移
(defun c:hh (/  bz ss aba2 aba1 abb aba aba4 aba3 aaa aac aab pt1 pt3  pt1x pt1y pt3x pt3y pt aba_1);;快速偏移
  (setvar "CMDECHO" 0)
  (command "undo" "be")
  (command "ucs" "w")
(setq bz(getvar "OSMODE"))
  (setvar "OSMODE" 0)
(setq ss(ssget)aba2(sslength ss) aba1 0)
(setq abb(GETREAL "\n输入偏移值:"))
(INITGET 128 "Nai Wai")
(setq aba(getkword"\n指定要向内偏(N)外偏(W):"))
(IF(= ABA "Nai")
(progn (repeat aba2
    (setq aba4(ssname SS aba1))
    (setq aba3(entget aba4))
       (setq aaa 10
     aac (assoc 10 aba3)
     aab (nth aaa aba3)
      (while (/= aab aac)
        (setq aab (nth aaa aba3))
        (setq aaa (+ aaa 1))
      (setq pt1 (cdr (nth (- aaa 1) aba3))
     pt3 (cdr (nth (+ aaa 7) aba3))
(SETQ PT1X (CAR PT1)
         PT3X (CAR PT3)
         PT1Y (CADR PT1)
         PT3Y (CADR PT3)
   (SETQ PTX (/ (+ PT1X PT3X) 2)
         PTY (/ (+ PT1Y PT3Y) 2)
         PT  (LIST PTX PTY)
   (command "OFFSET" abb aba4 pt "")
    (setq aba1(+ aba1 1))
(progn (setq aba_1(getpoint "\n指定偏移方向"))
  (repeat aba2
  (command "OFFSET" abb aba4 aba_1 "")
  (command "undo" "e")
  (command "ucs" "p")
  (setvar "OSMODE" bz)
  (setvar "CMDECHO" 1)
GMT+8, 2025-10-8 06:27 , Processed in 0.189483 second(s), 29 queries , Gzip On.
