查看: 683|回复: 0
[提问] 各位大侠,如何把这个改编下,可以吧填充的文字面积标注到图纸上
发表于 2020-8-28 09:30:14 | 显示全部楼层 |阅读模式
选择多个填充可以分别标注到每个填充的中心上去
(vl-load-com)
(defun c:tcx (/ thisdrawing modelspace cset hname area ll na)
  (setq        thisdrawing (vla-get-activedocument (vlax-get-acad-object))
        modelspace  (vla-get-modelspace thisdrawing)
  (if (not (vl-catch-all-error-p
             (setq cset
                    (vl-catch-all-apply
                      'vla-item
                      (list
                        (vla-get-selectionsets
                          thisdrawing
                        "CURRENT"
    (vla-delete cset)
  (if (ssget '((0 . "hatch")))
      (vlax-for        obj (vla-get-activeselectionset thisdrawing)
        (setq hname (vla-get-patternname obj)
              area  (/ (vl-catch-all-apply ' vla-get-area (list obj) ) 1000000)
        (if (= (type area) 'REAL)
          (if ll
            (if        (setq na (assoc hname ll))
              (setq ll (subst (list hname (+ area (cadr na))) na ll))
              (setq ll (cons (list hname area) ll))
            (vla-put-color obj acred)
            (vla-highlight obj actrue)
  (princ ll)
GMT+8, 2025-9-18 18:54 , Processed in 0.186358 second(s), 26 queries , Gzip On.
