查看: 944|回复: 3
[源码] 求大神指点左键线型标注结束,右键启动连续标注
发表于 2020-9-2 09:08:06 | 显示全部楼层 |阅读模式
(defun c:da(/ oldlay)
(setq oldlay (getvar"clayer"))
(if (= nil (tblsearch"layer" "dim"))
(command "layer" "n" "dim" "c" "4" "dim" "l" "continuous" "dim" "")
(setvar "clayer" "dim")
                (command "dimtoh"   "off"  )  ;非半径标注---------------------------------------------------
(princ"\n请选择标注点:")
(command "dimlinear" )      ;发出标注命令
(while (> (getvar "CMDACTIVE") 0) (command PAUSE));等待前一命令完成
                (command "_dimcontinue")                ;-------------------------------------------------------2020-08-31增加连续标注
                (while (> (getvar "CMDACTIVE") 0) (command PAUSE)); ;------------------------------------2020-08-31增加连续标注
发表于 2020-9-2 14:25:54 | 显示全部楼层
  (setq oldlay (getvar "clayer"))
  (command "-layer" "m" "dim" "c" "4" "" "l" "continuous" "" "")
  (command "dimtoh" "off")  ;非半径标注
  (princ "\n请选择标注点:")
  (command "dimlinear")     ;发出标注命令
  (while (> (getvar "CMDACTIVE") 0) (command PAUSE)) ;等待前一命令完成
  (if (/= (getpoint "\n右键连续标注: ") nil) (progn
    (command "_dimcontinue") ;2020-08-31增加连续标注
  (setvar "CLAYER" oldlay)
wuzheng80425 + 1
 楼主| 发表于 2020-9-2 21:27:29 | 显示全部楼层
  (command "-layer" "m" "dim" "c" "4" "" " ...
谢谢版主,学习了,反观自己,看来还是自己的基础没打好
发表于 2020-9-3 20:41:32 | 显示全部楼层
支持支持,,,学习学习
GMT+8, 2025-5-1 09:33 , Processed in 0.168201 second(s), 29 queries , Gzip On.
