查看: 1856|回复: 15
学习VBA开发发生了一些问题,新人求教
发表于 2020-9-2 10:40:49 | 显示全部楼层 |阅读模式
本人在学习《AutoCADVBA&VB.NET开发基础与实例教程》一书中编写代码实现有一点问题。关键对于动态数组的实现有一点问题,图形的实现效果也与书中不同,本人希望能得到大佬的指点一下。因书中的模块都会在后面用到,所以希望能解决一下。http://bbs.mjtd.com/forum.php?mod=attachment&aid=MTEwNjYzfDc3ZjU2ODEzZjY3YzAxNDA1NTkwYTBhMTFjOGI1ZTExfDE3NDc5MjQzMTg%3D&request=yes&_f=.dvb
 楼主| 发表于 2020-9-7 10:03:12 | 显示全部楼层
sgwsssxm 发表于 2020-9-7 00:18
If i Mod 2 = 0 Then
    point(0) = centerpoint(0) + radius * Sin((i / 2) * sideAngle)
    verts. ...
好的,问题现在已解决,多谢帮助。
发表于 2020-9-7 10:23:32 | 显示全部楼层
这就是m_bFirstItem的问题了,我说的两个地方都改了,最后显示效果才能对上。
 楼主| 发表于 2020-9-4 13:30:04 | 显示全部楼层
Option Explicit
Private m_verts() As Double
Private Sub Class_Initialize()
ReDim m_verts(1)
Dim m_bFirstItem As Boolean
m_bFirstItem = True
End Sub
Public Function Append(ByVal point As Variant)
Debug.Assert (VarType(point) = vbArray + vbDouble)
Debug.Assert (UBound(point) >= 1)
If (m_bFirstItem) Then
        m_bFirstItem = False
Else
ReDim Preserve m_verts(UBound(m_verts) + 2)
End If
m_verts(UBound(m_verts) - 1) = point(0)
m_verts(UBound(m_verts)) = point(1)
End Function
Public Function InsertAt(ByVal i As Integer, ByVal point As Variant) As Boolean
    If (i = 0) Then
        m_verts(0) = point(0)
        m_verts(1) = point(1)
    Else
        InsertAt = False
        Exit Function
    End If
Else
    If (i < 0 Or i > GetCount()) Then
        InsertAt = False
        Exit Function
    Else
        If (i <> GetCount()) Then
            Dim j As Integer
            For j = UBound(m_verts) To (i + 1) * 2 Step -1
                m_verts(j) = m_verts(j - 2)
            Next j
        End If
        m_verts(i * 2) = point(0)
        m_verts(i * 2 + 1) = point(1)
        InsertAt = True
    End If
End If
End Function
Public Function GetCount() As Integer
        GetCount = 0
    Else
        GetCount = (UBound(m_verts) + 1) / 2
    End If
End Function
Public Function RemoveLast() As Boolean
    If (GetCount() > 1) Then
        ReDim Preserve m_verts(UBound(m_verts) - 2)
        RemoveLast = True
   ElseIf (GetCount() = 1) Then
        m_verts(0) = 0
        m_verts(1) = 0
        RemoveLast = True
        m_bFirstItem = True
    Else
        RemoveLast = True
    End If
End Function
Public Function RemoveAt(ByVal i As Integer) As Boolean
    If (i < 0 Or i > GetCount() - 1) Then
        RemoveAt = False
        Exit Function
    Else
        If (i <> GetCount() - 1) Then
            Dim j As Integer
            For j = i * 2 To UBound(m_verts) - 2
                m_verts(j) = m_verts(j + 2)
            Next j
        End If
            m_verts(0) = 0
            m_verts(1) = 0
            m_bFirstItem = True
        Else
        End If
    End If
End Function
Public Function SetPoints(ByVal points As Variant) As Boolean
    Debug.Assert (VarType(points) = vbArray + vbDouble)
    Debug.Assert (UBound(points) Mod 2 = 1)
    ReDim m_verts(UBound(points))
    Dim i As Integer
    For i = 0 To UBound(points)
        m_verts(i) = points(i)
    Next i
End Function
Public Function GetAt(ByVal i As Integer, ByRef point As Variant) As Boolean
        GetAt = False
        Exit Function
    Else
        Dim vert(0 To 1) As Double
        SetPoint2d vert, m_verts(i * 2), m_verts(i * 2 + 1)
        point = vert
        GetAt = True
    End If
End Function
Public Function SetAt(ByVal i As Integer, ByVal point As Variant) As Boolean
    Debug.Assert (UBound(point) = 1)
    If (GetCount() = 0) Then
        SetAt = False
        Exit Function
    Else
            SetAt = False
            Exit Function
        Else
        End If
    End If
End Function
Public Function ToArray() As Variant
    ToArray = m_verts
End Function
 楼主| 发表于 2020-9-4 13:26:20 | 显示全部楼层
Public Function AddPolygon(ByVal centerpoint As Variant, ByVal sideCount As Double, ByVal radius As Double, Optional width As Double = 0, Optional angle As Double = 0) As AcadLWPolyline
    Dim math As New clsmath
    Dim sideAngle As Double
        sideAngle = (2 * math.PI()) / sideCount
    Dim verts As New cls2dPointArray
    Dim i As Integer
    Dim point(0 To 1) As Double
    For i = 0 To 2 * (sideCount - 1)
        If i Mod 2 = 0 Then
            verts.Append point
        Else
            point(1) = centerpoint(1) + radius * Cos((i / 2) * sideAngle)
        End If
    Next i
    Set AddPolygon = AddLWPolyline(verts.ToArray(), True, width)
    AddPolygon.Rotate centerpoint, angle
    AddPolygon.Update
End Function
发表于 2020-9-3 09:49:35 | 显示全部楼层
这个代码应该相当简单,请直接把代码以代码方式贴出来方便别人查看。
回到问题本身,这个程序相当简单,既然是图形错误,估计就是坐标错误导致,自己先检查下坐标值。
 楼主| 发表于 2020-9-4 10:24:32 | 显示全部楼层
Public Sub CreatePolygon()
    Dim centerpoint(0 To 2) As Double
    SetPoint3d centerpoint, 0, 0, 0
    Dim mSpace As New clsModelSpace
    mSpace.AddPolygon centerpoint, 6, 50
End Sub
 楼主| 发表于 2020-9-4 10:25:12 | 显示全部楼层
Public Function SetPoint3d(ByRef point As Variant, ByVal x As Double, ByVal y As Double, ByVal z As Double)
    Debug.Assert (LBound(point) = 0 And UBound(point) = 2)
    point(0) = x
    point(1) = y
    point(2) = z
End Function
 楼主| 发表于 2020-9-4 13:29:07 | 显示全部楼层
Public Function AddLeaderByPolyline(ByVal startPoint As Variant, ByVal endPoint As Variant, Optional widthScale As Double = 0.3) As AcadLWPolyline
    Debug.Assert (VarType(startPoint) = vbArray + vbDouble)
    Debug.Assert (VarType(endPoint) = vbArray + vbDouble)
    Debug.Assert (UBound(startPoint) = 1)
    Debug.Assert (UBound(endPoint) = 1)
    verts.Append startPoint
    verts.Append endPoint
    Set AddLeaderByPolyline = AddLWPolyline(verts.ToArray())
    Dim length As Double
    length = math.GetDistanceBetween2Point(startPoint, endPoint)
    AddLeaderByPolyline.SetWidth 0, length * widthScale, 0
End Function
 楼主| 发表于 2020-9-4 13:29:34 | 显示全部楼层
Public Function AddLWPolyline(ByVal verts As Variant, Optional closed As Boolean = False, Optional width As Double = 0) As AcadLWPolyline
    Debug.Assert (VarType(verts) = vbArray + vbDouble)
   Debug.Assert (UBound(verts) > 2 And UBound(verts) Mod 2 = 1)
    Set AddLWPolyline = ThisDrawing.ModelSpace.AddLightWeightPolyline(verts)
    If (closed) Then
        AddLWPolyline.closed = True
    End If
    AddLWPolyline.ConstantWidth = width
End Function
发表于 2020-9-7 00:18:34 | 显示全部楼层
cadlearner 发表于 2020-9-4 13:26
Public Function AddPolygon(ByVal centerpoint As Variant, ByVal sideCount As Double, ByVal radius A ...
If i Mod 2 = 0 Then
    verts.Append point
Else
End If
改成
If i Mod 2 = 0 Then
    point(0) = centerpoint(0) + radius * Cos((i / 2) * sideAngle)
    point(1) = centerpoint(1) + radius * Sin((i / 2) * sideAngle)
    verts.Append point
End If
你的 Sin 和 Cos 弄反了,至于你为什么用 i Mod 2 = 0 取偶数,再把 i/2 就看不出来你要干什么了。
发表于 2020-9-7 00:26:46 | 显示全部楼层
cadlearner 发表于 2020-9-4 13:30
Option Explicit
下面加一行
Private m_bFirstItem As Boolean
再把所有 Dim m_bFirstItem As Boolean 删除,全局变量要放在公共的位置,局部变量就算命名一样,也是互相独立、互不影响的。
GMT+8, 2025-5-22 22:31 , Processed in 0.198929 second(s), 27 queries , Gzip On.
