查看: 382|回复: 0
[提问] 程序添加求助
发表于 2020-9-7 16:50:06 | 显示全部楼层 |阅读模式
(defun C:sCC (/ ss a b d)
(command "-layer" "m" "0" "c" "7" "" "")
(command "-layer" "OFF" "DIM"  "OFF" "HID" "OFF" "CEN"  "")
  (setq
SS (ssget
  '((0 . "REGION,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE,ARC,INSERT"))      <====想在選取後 有ELLIPS, SPLINE 就不能執行下一段程序
  )        並且 ELLIPS, SPLINE 變成紅色
  )        假如 沒有ELLIPS , SPLINE  可以直接執行
  (prompt "選取圖號: ")
(setq a (entsel))
(setq b (entget (car a)))
(setq d (assoc 1 b))
  (setq w2 (print (cdr d)))
(if(findfile (SETQ w3 (STRCAT "d:/N/" w2 ".dxf" )) )
    (alert(strcat w3"已存在"))
  (command "filedia" "0")
(command "dxfout" w3 "O" SS "" "v" "R12" "")
(command "filedia" "1")))
試很多寫法都沒有成功    懇求高手幫忙發錯地發不好意思
GMT+8, 2025-5-17 20:58 , Processed in 0.160394 second(s), 25 queries , Gzip On.
