- 积分
- 554
- 明经币
- 个
- 注册时间
- 2016-9-30
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
(defun C:sCC (/ ss a b d)
(command "-layer" "m" "0" "c" "7" "" "")
(command "-layer" "OFF" "DIM" "OFF" "HID" "OFF" "CEN" "")
(setq
SS (ssget
'((0 . "REGION,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE,ARC,INSERT")) <====想在選取後 有ELLIPS, SPLINE 就不能執行下一段程序
) 並且 ELLIPS, SPLINE 變成紅色
) 假如 沒有ELLIPS , SPLINE 可以直接執行
(prompt "選取圖號: ")
(setq a (entsel))
(setq b (entget (car a)))
(setq d (assoc 1 b))
(setq w2 (print (cdr d)))
(if(findfile (SETQ w3 (STRCAT "d:/N/" w2 ".dxf" )) )
(alert(strcat w3"已存在"))
(command "filedia" "0")
(command "dxfout" w3 "O" SS "" "v" "R12" "")
(command "filedia" "1")))
試很多寫法都沒有成功 懇求高手幫忙
