查看: 2016|回复: 6
[提问] 写了一个功能:框选文字、直线分别归各自图层,想让改成一键就可以做到?
发表于 2020-9-16 20:11:19 | 显示全部楼层 |阅读模式
(defun c:dh1()
(setq ssg (ssget ":s" '((0 . "TEXT,mtext"))))
(sssetfirst nil ssg )
(command "change" ssg "" "p" "La" "8文字层" "" )
(defun c:dh2()
(setq ssg (ssget ":s" '((0 . "line"))))
(command "change" ssg "" "p" "La" "2细实线" "" )
这是本人写的,需要执行2次,想改成一键就可以做到的单行文字去文字层,直线去细实线层
发表于 2020-9-16 20:50:40 | 显示全部楼层
(defun c:dh( / ssg ssg1 ssg2)
(setq ssg (ssget ":s" '((0 . "TEXT,mtext,line"))))
(setq ssg1 (ssget "p" '((0 . "TEXT,mtext"))))
(command "._Select" ssg "_Remove" ssg1 "")
(setq ssg2 (ssget "p"))
(command "change" ssg1 "" "p" "La" "8文字层" "" )
(command "change" ssg2 "" "p" "La" "2细实线" "" )
试一下
 楼主| 发表于 2020-9-16 21:11:14 | 显示全部楼层
(setq ssg1 (ssget ...
(defun c:TT()
        (setq n(sslength ssg))
        (setq i 0)
        (while(< i n)
          (setq si(ssname ssg i))
          (setq k(entget si))
          (setq m(cdr(assoc 0 k)))
          (if(= m "LINE")
            (command "change" si "" "p" "La" "2细实线" "" )
            (command "change" si "" "p" "La" "8文字层" "" )
          (setq i(+ i 1))
谢谢老师
发表于 2020-9-16 21:17:56 | 显示全部楼层
zhangcan0515 发表于 2020-9-16 21:11
(defun c:TT()
不错,你的这样更安全些
发表于 2020-9-16 22:38:41 | 显示全部楼层
  1. (defun c:tt ()
  2.   (if (setq ss (ssget '((0 . "TEXT,mtext,line"))))
  3.     (if        (setq ssl (ssget "p" '((0 . "line"))))
  4.       (progn
  5.         (command "chprop" ssl "" "La" "2细实线" "")
  6.         (command "select" ss "r" ssl "")
  7.         (command "chprop" (ssget "p") "" "La" "8文字层" "")
  8.       )
  9.       (command "chprop" ss "" "La" "8文字层" "")
  10.     )
  11.   )
  12.   (princ)
  13. )
 楼主| 发表于 2020-9-17 09:47:35 | 显示全部楼层
谢谢院长捧场!!
发表于 2021-11-5 17:31:38 | 显示全部楼层
学习了学习了,太优秀了
GMT+8, 2025-5-17 08:24 , Processed in 0.160981 second(s), 26 queries , Gzip On.
