查看: 1534|回复: 1
AutoCAD 2005 命令和系统变量
发表于 2004-3-21 12:10:00 | 显示全部楼层 |阅读模式
文章来源:AutoCAD 2005 Readme >> Command and System Variable History New Commands:
The following commands are new in AutoCAD 2005:
ARCHIVE
ASSISTCLOSE
BORROWLICENSE
FIELD
MARKUP
MARKUPCLOSE
MATCHCELL
NETLOAD
NEWSHEETSET
OPENDWFMARKUP
OPENSHEETSET
RETURNLICENSE
SHEETSET
SHEETSETHIDE
TABLE
TABLEDIT
TABLEEXPORT
TABLESTYLE
TEXTTOFRONT
UPDATEFIELD
UPDATETHUMBSNOW
VIEWPLOTDETAILS
VPMAX
VPMIN Changed Commands:
The following commands have been changed in AutoCAD 2005:
3DCONFIG
ARRAY
ASSIST
ATTDEF
ATTEDIT
BATTMAN
BHATCH
BLOCK
BMPOUT
BREAK
CHAMFER
COPY
COPYCLIP
CUTCLIP
DDEDIT
DRAWORDER
EATTEDIT
ETRANSMIT
EXPLODE
FILLET
FIND
HATCH
HATCHEDIT
HYPERLINKOPTIONS
JPGOUT
LAYER
MATCHPROP
MIRROR
MIRROR3D
MREDO
MTEXT
OFFSET
OOPS
OPTIONS
PAGESETUP
PASTEBLOCK
PASTECLIP
PASTEORIG
PASTESPEC
PEDIT
PNGOUT
PLOT
PUBLISH
PURGE
REDO
REFEDIT
REVCLOUD
SAVEAS
SETVAR
SPELL
TEXT
TIFOUT
TRIM
U
UNDO
WBLOCK
WMFOUT
XBIND New System Variables:
The following system variables are new in AutoCAD 2005:
ASSISTSTATE
BACKGROUNDPLOT
CTABLESTYLE
DRAWORDERCTL
FIELDDISPLAY
FIELDEVAL
HPDRAWORDER
HPGAPTOL
MSOLESCALE
OLEFRAME
PLOTOFFSET
RASTERDPI
SSFOUND
SSLOCATE
SSMAUTOOPEN
SSMSTATE
TASKBAR
Note: TASKBAR is not a true system variable, and is not available using SETVAR or GETVAR.
TBCUSTOMIZE
UPDATETHUMBNAIL
VPMAXIMIZEDSTATE
XREFTYPE Changed System Variables:
The following system variables have been changed in AutoCAD 2005:
DBMOD
OLEQUALITY
发表于 2004-3-21 12:19:00 | 显示全部楼层
晕!不知道是干什么的,再配上一些注释就好了,呵呵!
GMT+8, 2025-5-2 17:17 , Processed in 0.173712 second(s), 23 queries , Gzip On.
