查看: 1092|回复: 1
[提问] 单选如何修改成框选?
发表于 2020-10-6 12:35:56 | 显示全部楼层 |阅读模式
(defun c:tt ()
  (if (and (setq s1 (car (entsel "\n选择: ")))
           (xyp-Etype s1 "insert")
    (foreach a (xyp-Block-OnameList (vlax-ename->vla-object s1))
      (cond ((xyp-Etype (vlax-vla-object->ename a) "line")
             (vla-put-color a 1)
            ((xyp-Etype (vlax-vla-object->ename a) "*text")
             (vla-put-color a 3)
  (command "REGEN" )
发表于 2020-10-6 15:30:19 | 显示全部楼层
(defun c:tt ()
  (if (setq ssa (ssget '((0 . "insert")))) ;可单选、多选、框选
          (setq i 0)
          (setq n (sslength ssa))
          (repeat n
              (setq s1 (ssname ssa i))
                              (vla-put-color a 1)
                              (vla-put-color a 3)
              (setq i (1+ i))
          (command "REGEN" )
zhangcan0515 + 1 可以了!谢谢老师帮助!!加强学习
GMT+8, 2025-5-17 17:36 , Processed in 0.174425 second(s), 28 queries , Gzip On.
