查看: 3511|回复: 3
[2021] AutoCAD2010-2021补丁包官网下载地址
发表于 2020-10-11 14:00:20 | 显示全部楼层 |阅读模式
收集整理了一下,AutoCAD2010-2021的补丁包,建议安装使用,这样CAD中一些莫名其妙的问题估计就被修复了。补丁包如下:
AutoCAD2021:
https://up.autodesk.com/2021/ACD/FB48C738-141C-4F14-BDC5-57BBA246D404/AutoCAD_2021.1_Update_64bit.exe
AutoCAD2020:
https://up.autodesk.com/2020/ACD/C1116C06-6497-434A-BCDB-158218DDC3F9/AutoCAD_2020.1.3_Update_64bit.exe
AutoCAD2019:
https://up.autodesk.com/2019/ACD/9BFD102A-51F1-4C11-9ECC-11D9414EBF44/AutoCAD_2019.1.2_Update_64bit.exe
https://up.autodesk.com/2019/ACD/80967F4E-4517-4F40-A73F-970B6E644F6E/AutoCAD_2019.1.2_Update_32bit.exe
AutoCAD2018:
https://up.autodesk.com/2018/ACD/5C9FB70F-6354-4845-B3E6-9EA501F3C343/AutoCAD_2018.1.2_Update_64bit.exe
https://up.autodesk.com/2018/ACD/1A9A3659-5EB7-48C1-9053-EBDEAC15D647/AutoCAD_2018.1.2_Update_32bit.exe
AutoCAD2017:
https://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2017_SP1_64bit.exe
https://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2017_SP1_32bit.exe
AutoCAD2016:
https://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2016.0.11_Update_x64.exe
https://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2016.0.11_Update_x86.exe
https://download.autodesk.com/us/support/files/autocad_2016_service_pack_1/AutoCAD_2016_SP1_64bit.exe
https://download.autodesk.com/us/support/files/autocad_2016_service_pack_1/AutoCAD_2016_SP1_32bit.exe
AutoCAD2015:
https://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2015_SP2_64bit.exe
https://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2015_SP2_32bit.exe
AutoCAD2014:
https://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2014_SP1_64bit.exe
https://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2014_SP1_32bit.exe
AutoCAD2013:
http://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2013_SP2_64bit.exe
http://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2013_SP2_32bit.exe
AutoCAD2012:
http://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2012_SP2_64bit.exe
http://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD_2012_SP2_32bit.exe
AutoCAD2011:
http://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD2011Update2x64.exe
http://knowledge.autodesk.com/sites/default/files/file_downloads/AutoCAD2011Update2.exe
AutoCAD2010:
http://knowledge.autodesk.com/sites/default/files/file_downloads/autocad2010update2x64.exe
http://knowledge.autodesk.com/sites/default/files/file_downloads/autocad2010update2.exe
发表于 2020-10-11 15:33:08 | 显示全部楼层
感谢楼主分享!!!
发表于 2020-10-13 15:13:25 | 显示全部楼层
安装的精简版,才400多m,补丁就800多m,可以用不?
发表于 2020-10-14 13:59:00 | 显示全部楼层
辛苦了,楼主。谢谢分享。
GMT+8, 2025-6-7 07:13 , Processed in 0.156030 second(s), 26 queries , Gzip On.
