- 积分
- 4209
- 明经币
- 个
- 注册时间
- 2013-1-9
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
各位大神帮忙看下这个合并文字的程序,这个程序是合并文字的,在同一行的文字会合并大一起,不过有些文字距离很大的一起选中也会合并到一起,希望大神修改下,添加一个距离,文字之间距离小于多少的才和并到一起,大于多少的独立自行合并
(defun c:DHHB (/ sort_text_by_column1 sslst textlst scale)
;;按行排列文字,nscale为字高的倍数,设为0.5,即文字竖向间距小于0.5倍字高,则按一行考虑
(defun sort_text_by_column1
(sstext nscale / n rtnlst
y rtnlst1 rtnlst2 space1 space2
aa bb cc dd
(setq n -1
rtnlst nil
(repeat (sslength sstext)
(setq rtnlst (cons (ssname sstext (setq n (1+ n))) rtnlst))
(setq rtnlst
(vl-sort
rtnlst
'(lambda (a b)
(setq a (vlax-ename->vla-object a)
b (vlax-ename->vla-object b)
(vla-GetBoundingBox a 'aa 'bb)
(vla-GetBoundingBox b 'cc 'dd)
(if
(< (abs (- (vlax-safearray-get-element aa 1)
(vlax-safearray-get-element cc 1)
(abs
(* nscale
(- (vlax-safearray-get-element bb 1)
(< (vlax-safearray-get-element aa 0)
(vlax-safearray-get-element cc 0)
(> (vlax-safearray-get-element aa 1)
(setq y (cadr (zgx-get-dxf 10 (car rtnlst) 1)))
(setq rtnlst1 nil
rtnlst2 nil
(mapcar
'(lambda (x)
(vla-GetBoundingBox (vlax-ename->vla-object x) 'aa 'bb)
(if
(< (abs (- (cadr (zgx-get-dxf 10 x 1)) y))
(* nscale
(abs (- (vlax-safearray-get-element bb 1)
(setq rtnlst1 (append rtnlst1 (list x)))
(setq rtnlst2 (append rtnlst2 (list rtnlst1)))
(setq y (cadr (zgx-get-dxf 10 x 1)))
(setq rtnlst1 nil
rtnlst
(defun zgx-chg-dxf (en code newdata / endata)
(setq endata (entget en))
(if (assoc code endata)
(setq
endata (subst (cons code newdata) (assoc code endata) endata)
(setq
endata (append endata (list (cons code newdata)))
(entmod endata)
(defun zgx-get-dxf (code entname kk)
(if (= kk 2)
(assoc code (entget entname))
(cdr (assoc code (entget entname)))
(prompt "\n选择需要合并的文字[更改间距系数]:")
(setq sslst (ssget '((0 . "text,swr_text"))))
(while (not sslst)
(setq scale (getreal "\n输入间距系数[默认0.5]:"))
(if (not scale)
(setq scale 0.5)
(setq sslst (ssget '((0 . "text,swr_text,tch_text"))))
(if (not scale)
(setq scale 0.5)
(setq sslst (sort_text_by_column1 sslst scale)
textlst (mapcar '(lambda (c)
(apply 'strcat c)
(mapcar '(lambda (x)
(mapcar '(lambda (a)
(zgx-get-dxf 1 a 1)
sslst
(vla-startundomark
(vla-get-ActiveDocument (vlax-get-acad-object))
;;改变每行第一个文字值
(mapcar '(lambda (a b)
(zgx-chg-dxf (car a) 1 b)
sslst
textlst
(setq sslst (apply 'append
(mapcar 'cdr
sslst
(foreach n sslst
(entdel n)
(vla-endundomark
(princ "\n文字合并结束!")
