查看: 1461|回复: 3
总觉得现在的软件太多了,学vl用处不是太?
发表于 2004-3-21 16:49:00 | 显示全部楼层 |阅读模式
请各位发表自己的意见
发表于 2004-3-21 18:54:00 | 显示全部楼层
我英语比较差,使用原文来掩盖一下了。
Here is a simple checklist for determining which API may be right for your project:
ObjectARX:
bullet
You are most comfortable working in C or C++
bullet
You need the absolute maximum amount of control over AutoCAD and Windows
bullet
You need to write custom objects
bullet
You need access to things which are not exposed to VBA or Lisp
bullet
You require more speed than can be had using VBA or Lisp
bullet
Your workplace requires applications be developed in C or C++
bullet
You need to use libraries external to AutoCAD which are only available to C or C++
VBA:
bullet
You are most comfortable working in VBA
bullet
You need to use a dialogs
bullet
You need to interface with Windows or one of the Microsoft office programs like Excel
bullet
You are new to developing for AutoCAD or are new to developing period
bullet
You require maximum speed of development time yet are not overly worried about application speed
bullet
You know you are going to need a lot of help from Autodesk getting your application written
Lisp:
bullet
The world ended and there are no other tools available
bullet
You are most comfortable working in Lisp
bullet
You are working with an AutoCAD version prior to 2000
bullet
You are working in one of those gray areas in AutoCAD where Lisp can do something that would require a huge amount of VB knowledge to accomplish the same thing.
bullet
Your workplace requires it
bullet
Your workplace may need to interface existing Lisp libraries with your tool
bullet
You enjoy pain
bullet
You don't need any dialogs or graphical user interaction other than the command line/screen pics in your application
bullet
Parens make you happy (oh look here come the men in white coats for you now)
发表于 2004-3-21 18:56:00 | 显示全部楼层
抱歉我没想到会粘成这样: Here is a simple checklist for determining which API may be right for your project: ObjectARX: You are most comfortable working in C or C++
VBA: You are most comfortable working in VBA
Lisp: The world ended and there are no other tools available
You enjoy pain
发表于 2004-3-21 21:02:00 | 显示全部楼层
GMT+8, 2025-8-19 09:06 , Processed in 0.273258 second(s), 26 queries , Gzip On.
