查看: 811|回复: 2
[提问] 能把帮忙改为先选中图形再运执行?谢谢
发表于 2020-11-3 12:26:23 | 显示全部楼层 |阅读模式
2明经币
(defun c:scc  (/ sc a b)
  (if (null oldscale) (setq oldscale 2.0))
  (initget 6)
  (setq sc (getreal (strcat "\n缩放倍数<" (rtos oldscale 2 2)">:")))
  (if (null sc) (setq sc oldscale) (setq oldscale sc))
  (while (ssget)
    (vlax-for        obj
                (vla-get-ActiveSelectionSet
                  (vla-get-ActiveDocument (vlax-get-acad-object)))
        (if (not (VL-CATCH-ALL-ERROR-P
                   (VL-CATCH-ALL-APPLY
                     'vla-GetBoundingBox
                     (list obj 'a 'b))))
            (vla-ScaleEntity
              obj
              (vlax-3d-point
                (mapcar
                  '(0.5 0.5 0.5)
                  (apply 'mapcar
                         (cons '+
                               (mapcar 'vlax-safearray->list
                                       (list a b))))))
              sc
最佳答案
查看完整内容
是這樣嗎? (defun c:scc (/ sc a b) (while (ssget) (if (null oldscale) (setq oldscale 2.0)) (initget 6) (setq sc (getreal (strcat "\n缩放倍数:"))) (if (null sc) (setq sc oldscale) (setq oldsc ...
发表于 2020-11-3 12:26:24 | 显示全部楼层
是這樣嗎?
  (while (ssget)
    (initget 6)
    (vlax-for        obj
                   (VL-CATCH-ALL-APPLY
                     'vla-GetBoundingBox
                     (list obj 'a 'b))))
            (vla-ScaleEntity
              obj
              (vlax-3d-point
                (mapcar
                  '(0.5 0.5 0.5)
                  (apply 'mapcar
                         (cons '+
                                       (list a b))))))
              sc
 楼主| 发表于 2020-11-3 18:00:30 | 显示全部楼层
bssurvey 发表于 2020-11-3 13:54
是這樣嗎?
  (while (ssget) ...
是这样的,谢谢
GMT+8, 2025-5-17 14:33 , Processed in 0.176657 second(s), 25 queries , Gzip On.
