- 积分
- 4729
- 明经币
- 个
- 注册时间
- 2007-7-15
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2020-11-19 21:29:32
显示全部楼层
你这个问题可以去看一下Et工具里的“Copym.lsp” 再看了一下,你用line可以了。满三个点,你就头尾相连。填充,隐藏。选点。就这样重复~
;; Copym.lsp - Multiple copy command with measure, divide and array capabilities.
;; Copyright ?1999 by Autodesk, Inc.
;; Your use of this software is governed by the terms and conditions
;; of the License Agreement you accepted prior to installation of this
;; software. Please note that pursuant to the License Agreement for this
;; software, "[c]opying of this computer program or its documentation
;; except as permitted by this License is copyright infringement under
;; the laws of your country. If you copy this computer program without
;; permission of Autodesk, you are violating the law."
;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;; UNINTERRUPTED OR ERROR FREE.
