查看: 586|回复: 3
[提问] 此处为何不能用循环语句?
发表于 2020-11-26 06:34:37 | 显示全部楼层 |阅读模式
;;问题:对话框中RadioGroup显示多行实现单选和互斥时,逐行调用action_tile与调用循环action_tile效果为何不同?
;;问题描述:boxed_radio单行或单列排不下,只能多行多列,但各列不互斥,列间无法实现单选。
;;         于是逐行调用action_tile来写互斥代码时,逐行调用action_tile(代码中方法一)可以实现预期功能,
;;         但改用循环语句调用action_tile(代码中方法二)却始终达不到目的。
;;      请热心人帮我找一下问题出在哪里。谢谢!
(defun c:tt ( / fname fn dcl_id i )
        ;;写对话框文件
        (setq fname (vl-filename-mktemp nil nil ".dcl"))
        (setq fn (open fname "w"))
        (write-line "temp:dialog{label=\"多行多列radio例示\";" fn)
        (write-line "" fn)
        (write-line ":boxed_radio_row{label=\"装夹方式>系数C(多选一): \";" fn)
        (write-line "key=\"E3\";value=\"E3R1\";" fn)
        (write-line ":radio_column{" fn)
        (write-line ":radio_button{label=\"三爪\"; key=\"E3R1\";}" fn)
        (write-line ":radio_button{label=\"三爪顶尖\"; key=\"E3R2\";}" fn)
        (write-line ":radio_button{label=\"三爪中心架\"; key=\"E3R3\";}" fn)
        (write-line ":radio_button{label=\"三爪顶尖\"; key=\"E3R4\";}" fn)
        (write-line ":radio_button{label=\"两头顶尖(梅花)\"; key=\"E3R5\";}" fn)
        (write-line "}" fn)
        (write-line ":radio_button{label=\"四爪(专用胎具)\"; key=\"E3R6\";}" fn)
        (write-line ":radio_button{label=\"四爪顶尖\"; key=\"E3R7\";}" fn)
        (write-line ":radio_button{label=\"四爪中心架\"; key=\"E3R8\";}" fn)
        (write-line ":radio_button{label=\"四爪顶尖\"; key=\"E3R9\";}" fn)
        (write-line ":radio_button{label=\"芯轴顶尖(花键)\"; key=\"E3R10\";}" fn)
        (write-line "}" fn)
        (write-line ":radio_button{label=\"外涨胎\"; key=\"E3R11\";}" fn)
        (write-line ":radio_button{label=\"定心模具\"; key=\"E3R12\";}" fn)
        (write-line ":radio_button{label=\"弯板\"; key=\"E3R13\";}" fn)
        (write-line ":radio_button{label=\"花盘\"; key=\"E3R14\";}" fn)
        (write-line "}" fn)
        (write-line "" fn)
        (write-line "}" fn)
        (write-line "" fn)
        (write-line ":edit_box{label=\"你选择了: \"; key=\"num\";}" fn)
        (write-line "ok_cancel;" fn)
        (write-line "errtile;}" fn)
        (close fn)
        (setq dcl_id (load_dialog fname))
        (if (not (new_dialog "temp" dcl_id))
                (exit)
        );if
        ;;实现互现互斥(方法一):
        (action_tile "E3R1" "(cleari \"E3\" 1 14)(set_tile \"num\" \"1\")")
        (action_tile "E3R2" "(cleari \"E3\" 2 14)(set_tile \"num\" \"2\")")
        (action_tile "E3R3" "(cleari \"E3\" 3 14)(set_tile \"num\" \"3\")")
        (action_tile "E3R4" "(cleari \"E3\" 4 14)(set_tile \"num\" \"4\")")
        (action_tile "E3R5" "(cleari \"E3\" 5 14)(set_tile \"num\" \"5\")")
        (action_tile "E3R6" "(cleari \"E3\" 6 14)(set_tile \"num\" \"6\")")
        (action_tile "E3R7" "(cleari \"E3\" 7 14)(set_tile \"num\" \"7\")")
        (action_tile "E3R8" "(cleari \"E3\" 8 14)(set_tile \"num\" \"8\")")
        (action_tile "E3R9" "(cleari \"E3\" 9 14)(set_tile \"num\" \"9\")")
        (action_tile "E3R10" "(cleari \"E3\" 10 14)(set_tile \"num\" \"10\")")
        (action_tile "E3R11" "(cleari \"E3\" 11 14)(set_tile \"num\" \"11\")")
        (action_tile "E3R12" "(cleari \"E3\" 12 14)(set_tile \"num\" \"12\")")
        (action_tile "E3R13" "(cleari \"E3\" 13 14)(set_tile \"num\" \"13\")")
        (action_tile "E3R14" "(cleari \"E3\" 14 14)(set_tile \"num\" \"14\")")
        ;;实现互现互斥(方法二):
        ;(setq i 0)
        ;(repeat 14
        ;        (setq i (+ i 1))
        ;        (action_tile (strcat "E3R" (itoa i)) "(cleari \"E3\" i 14)(set_tile \"num\" (itoa i))")
        (start_dialog)
        (unload_dialog dcl_id)
);defun
;;===========多行多列boxed_radio单选互斥
;;key---"E3"
;;n---第n项选中
;;num---共有radio个数---14
(defun cleari ( key n num / i )
        (setq i 0)
        (while (< i num)
                (setq i (+ i 1))
                (if (/= i n)
                        ;(set_tile (strcat key "R" (itoa i)) "1")
                        (set_tile (strcat key "R" (itoa i)) "0")
发表于 2020-11-26 11:51:53 | 显示全部楼层
循环里的执行字符没对,对着方法一那核对下
(action_tile (strcat "E3R" (itoa i)) (strcat "(cleari \"E3\" "(itoa i)" 14)(set_tile \"num\" " "\" "(itoa i)" \")" ")"))
wrf610051 + 1 很给力!
发表于 2020-11-26 16:36:12 | 显示全部楼层
这种用poplist下拉表或list_box列表框可能更简单
http://bbs.mjtd.com/forum.php?mod=attachment&aid=MTExOTU3fDBmNWZiMTZmYmJiNjM3OWJiYWFhZDM5NDFmYmRkYTJjfDE3NDc0ODIwOTY%3D&request=yes&_f=.gifattach://111958.lsp
wrf610051 + 1 很给力!
 楼主| 发表于 2020-11-27 06:55:20 | 显示全部楼层
谢谢start4444,解决了我的问题;
谢谢xyp19664,给了我更多的帮助;
同时也感谢明经这个我们学知识的好平台。
GMT+8, 2025-5-17 19:41 , Processed in 0.193154 second(s), 33 queries , Gzip On.
