查看: 2329|回复: 16
[提问] 小程序报错:点击矩形,自动生成面积和重量标注
发表于 2020-12-3 19:49:37 | 显示全部楼层 |阅读模式
请问各位前辈,我想写一个小程序,实现:点击一矩形,自动在矩形中心处生成面积和重量的标注。以下是我撰写的程序,但是报错了:错误: 参数类型错误: lentityp nil,请问是什么原因呢?代码如下:
  1. (defun c:zs ()
  2.   (vl-load-com)
  3.   (setvar "cmdecho" 0)
  4.   (setvar "blipmode" 0)
  5.   (setvar "osmode" 0)
  6.   (setq en1 (entsel "Select an object:"))
  7.   (setq bh (getreal "Enter the first number:")
  8.   ch (getreal "Enter the second number:")
  9.   )
  10.   (setq en_data (entget (car en)))
  11.   (setq lx (cdr (assoc 0 en_data)))
  12.   (if (= lx "LWPOLYLINE")
  13.     (progn
  14.       (setq p1 (cdr (assoc 10 en_data)))
  15.       (setq listlength (length en_data))
  16.       (setq p2 (cdr (nth (- listlength 13) en_data)))
  17.       (setq p3 (cdr (nth (- listlength 9) en_data)))
  18.       (setq p4 (cdr (nth (- listlength 5) en_data)))
  19.       (setq midp (list (/ (+ (car p1) (car p3)) 2) (/ (+ (cadr p1) (cadr p3)) 2) 0))
  20.       (setq b1 (distance p1 p2))
  21.       (setq b2 (distance p2 p3))
  22.       (setq area (/ (* b1 b2) 1000000))
  23.       (setq weight (* (* area 0.06) 2.5))
  24.       (setq context1 (strcat (rtos area) "平," (rtos weight) "t"))
  25.       (entmake (list
  26.          '(0 . "TEXT")
  27.          '(100 . "AcDbEntity")
  28.          '(100 . "AcDbText")
  29.           (cons 11 (setq d1 (polar midp (* 1.5 pi) 330)))
  30.           (cons 10 (polar d1 pi 700))
  31.           (cons 40 300)
  32.           (cons 1 context1)
  33.          )
  34.        )
  35.     )
  36.   )
  37.   (princ)
  38. )
发表于 2020-12-5 22:43:31 | 显示全部楼层
rocking2008 发表于 2020-12-5 22:12
长老,能否加入圆、多边形、PL线画的封闭区域这3个对象。目前只能支持矩形。
(defun c:plzsA()
  (vl-load-com)
  (setvar "osmode" 0)
  (command "_undo" "be")
  (if (progn
           (princ "\n请选取圆、封闭多段线:")
                 (setq ssa (ssget '((0 . "LWPOLYLINE,CIRCLE"))))
         (setq i 0)
         (repeat (sslength ssa)
             (setq ent (ssname ssa i))
             (setq obj (vlax-ename->vla-object ent))
             (setq dxf (entget ent))
             (setq name (cdr (assoc 0 dxf)))
             (setq area (/ (vlax-curve-getArea obj) 1000000.0))
             (cond ((= name "CIRCLE")
                       (setq pmid (cdr (assoc 10 dxf)))
                   ((= name "LWPOLYLINE")
                       (If (= (vlax-get obj "Closed") -1)
                                (setq pts (mapcar 'cdr (vl-remove-if '(lambda(x)(/= (car x) 10)) dxf)))
                                (setq pmid (mapcar '/ (apply 'mapcar (cons '+ pts))
                                                      (list (length pts) (length pts))
                           (setq pmid nil)
             (If (/= pmid nil)
                     (entmake (list
                                    '(0 . "TEXT")
                                    '(100 . "AcDbText")
                                     (cons 1 context1)
                                     (cons 10 pmid)
                                     (cons 11 pmid)
                                     (cons 40 300) '(41 . 1.0)
                                     (cons 50 0.0) '(51 . 0.0)
                                    '(71 . 0) '(72 . 1) '(73 . 2)
             (setq i (1+ i))
  (command "_undo" "e")
发表于 2020-12-4 08:56:22 | 显示全部楼层
bai2000 发表于 2020-12-4 08:40
楼上的不错,能批量更好
(defun c:plzs()
  (vl-load-com)
  (setvar "osmode" 0)
  (if (progn
           (princ "\n请选取矩形:")
           (setq ssa (ssget  '((0 . "LWPOLYLINE")(90 . 4))))
         (setq i 0)
             (setq pmid (mapcar '(lambda( a b)(* 0.5 (+ a b))) (car pts) (caddr pts)))
             (setq area (/ (vlax-curve-getArea ent) 1000000.0))
             (entmake (list
                                '(0 . "TEXT")
                                '(100 . "AcDbText")
                                 (cons 1 context1)
                                 (cons 10 pmid)
                                 (cons 11 pmid)
             (setq i (1+ i))
发表于 2020-12-3 20:53:32 | 显示全部楼层
顺序一行一行的复制在命令行执行检查,我一般都这样
发表于 2020-12-3 22:34:43 | 显示全部楼层
(defun c:zs ()
  (vl-load-com)
  (setvar "osmode" 0)
  (if (setq ent (car (entsel "Select an LWPOLYLINE object:")))
         (setq jdgs (cdr (assoc 90 dxf)))
         (if (and (= name "LWPOLYLINE") (= jdgs 4))
                 (entmake (list
                                '(0 . "TEXT")
                                '(100 . "AcDbText")
                                 (cons 1 context1)
                                 (cons 10 pmid)
                                 (cons 11 pmid)
发表于 2020-12-4 08:40:29 | 显示全部楼层
楼上的不错,能批量更好
发表于 2020-12-4 10:18:27 来自手机 | 显示全部楼层
真好用,多谢分享*(╰╯)
 楼主| 发表于 2020-12-4 13:02:56 | 显示全部楼层
多谢各位前辈指导~
发表于 2020-12-5 22:05:20 | 显示全部楼层
这个重量的计算,area是面积,乖以0.06是厚度,2.5是什么物质的1立方的重量?
发表于 2020-12-5 22:12:23 | 显示全部楼层
yshf 发表于 2020-12-4 08:56
(defun c:plzs()
  (vl-load-com)
GMT+8, 2025-8-24 04:03 , Processed in 0.250386 second(s), 28 queries , Gzip On.
