查看: 2222|回复: 7
[提问] (求助)请问有没 有各位大神,帮忙把阿甘计算器增加一个功能
发表于 2020-12-9 09:30:03 | 显示全部楼层 |阅读模式
请教一下各位大神,目前阿甘计算器,在CAD里第一次启动,计算器的输入框是空的,输入计算数值后,按ESC结束,重新启用计算器的时候,上一次计算的内容还在输入框内,请问如何使它结束计算器对话框后,之前输入计算的框内数值清空,或者按DELETE也可以删掉,如果这两个都能优化实现就最好
;计算器
;结果自动复制到剪贴板,支持天正文字、天正标高
(setq GL-precision 0)  ;0为计算结果保留位数 自己根据需要修改
(setq GL-text "D:/历史记录.txt" ) ;历史记录文件路径,注意路径为反斜杠“/”,可根据需要修改位置
;不出现对话框,直接计算 命令:y1=加法 y2=减法 y3=乘法 y4=除法
(defun c:y1() (GL:jiafa))
(defun c:y2() (GL:jianfa))
(defun c:y3() (GL:chengfa))
(defun c:y4() (GL:chufa))
;阿甘CAD计算器
(vl-load-com)
(command "cal")(command)     ;先调用cal,否则后面cal函数无法使用
(setq GL-result "")          ;计算结果,全局变量
(setq GL-lst (list ""))
(defun c:CY(/ file)
  (if (not (setq file (open GL-text "r")))
      (setq file (open GL-text "w" ))
      (close file)
    (close file)
  (GL-xxjsq)
(defun GL-xxjsq (/ fname fn x dclid lin re file txt value reason)
       (if (not GL-result)
           (setq GL-result "")
       (setq fname (vl-filename-mktemp nil nil ".dcl" ))
       (setq fn (open fname "w" ))
       (foreach x '(
                     "  xxjsq : dialog{"
                     "  label=\"阿甘CAD计算器V1.1\";"
                     "  :boxed_column{"
                     "  label=\"自动计算\";"
                     "  :row {"
                     "      :button{key=\"1\";label=\"+\";width=4;}"
                     "      :button{key=\"2\";label=\"-\";width=4;}"
                     "      :button{key=\"3\";label=\"*\";width=4;}"
                     "      :button{key=\"4\";label=\"/\";width=4;}"
                     "  spacer_1;"
                     "  :boxed_column{"
                     "  label=\"手动计算\";"
                     "  :row {"
                     "     :edit_box{width=35;height=1;key =\"5\";allow_accept = true;}"
                     "            :button {"
                     "                is_default = true ;"
                     "                key = \"6\" ;"
                     "                label = \"计算\" ;"
                     "                width = 10 ;"
                     "  spacer_1;"
                     "  :row {"
                     "      :button{key=\"11\";label=\"C↑\";width=4;}"
                     "      :button{key=\"12\";label=\"C↓\";width=4;}"
                     "      :button{key=\"8\";label=\"拾取\";width=4;}"
                     "      :button{key=\"10\";label=\"插算式\";width=4;}"
                     "      :button{key=\"7\";label=\"插结果\";width=4;}"
                     "  spacer_1;"
                     "  :list_box {key=\"9\";label=\"历史记录\";width=30;height=5;}"
                     "      cancel_button;"
              (princ x fn)
              (write-line "" fn)
       (close fn)
       (setq fn (open fname "r" ))
       (setq dclid (load_dialog fname))
       (while (or (eq (substr (setq lin (vl-string-right-trim "\" fn)" (vl-string-left-trim "(write-line \"" (read-line fn)))) 1 2) "//" ) (eq (substr lin 1 (vl-string-search " " lin)) "" ) (not (eq (substr lin (+ (vl-string-search " " lin) 1) 9) " : dialog" ))))
       (new_dialog (substr lin 1 (vl-string-search " " lin)) dclid)
    (start_list "9")
    (if (equal GL-lst (list ""))
               txt (read-line file)
         (while (/= txt nil)
          (setq GL-lst (append GL-lst (list txt)))
          (setq txt (read-line file))
         (close file)
            (setq GL-lst (cdr GL-lst))
            (setq GL-lst (reverse GL-lst))
    (mapcar 'add_list GL-lst)
    (end_list)
    (set_tile "5" GL-result)
    (mode_tile "5" 2)
    (Vlax-Invoke-Method (Vlax-Get-Or-Create-Object "WScript.Shell" ) 'Sendkeys "{End}")
       (action_tile "5" "(setq GL-result $Value)")
       (action_tile "1" "(done_dialog 1)" )
       (action_tile "2" "(done_dialog 2)" )
       (action_tile "3" "(done_dialog 3)" )
       (action_tile "4" "(done_dialog 4)" )
       (action_tile "6" "(GL:key6)")
       (action_tile "7" "(done_dialog 7)" )
       (action_tile "8" "(done_dialog 8)" )
       (action_tile "9" "(GL:update-edit $value $reason)")
       (action_tile "10" "(done_dialog 10)" )
       (action_tile "11" "(GL:key11)" )
       (action_tile "12" "(GL:key12)" )
       (action_tile "cancel" "(done_dialog 0)" )
       (setq re (start_dialog))
       (cond
            ((= re 1) (GL:jiafa)(GL:update)(GL-xxjsq))
            ((= re 2) (GL:jianfa)(GL:update)(GL-xxjsq))
            ((= re 3) (GL:chengfa)(GL:update)(GL-xxjsq))
            ((= re 4) (GL:chufa)(GL:update)(GL-xxjsq))
            ((= re 7) (GL:crjswz GL-result))
            ((= re 8) (GL:key8))
            ((= re 10) (GL:crjswz (strcat GL-Num "=" GL-result)))
       (unload_dialog dclid)
       (close fn)
       (vl-file-delete fname)
(defun GL:jiafa ()(GL:Galculate (GL:GetNumber "+")))
(defun GL:jianfa ()(GL:Galculate (GL:GetNumber "-")))
(defun GL:chengfa ()(GL:Galculate (GL:GetNumber "*")))
(defun GL:chufa ()(GL:Galculate (GL:GetNumber "/")))
;手动计算
(defun GL:key6 ()
  (setq GL-result (get_tile "5"))
  (if (/= GL-result "")
     (if (GL:Galculate GL-result)
         (mode_tile "5" 2)
         (GL:update)
;拾取
(defun GL:key8 (/ num)
  (if (setq num (GL:GetNumber "+"))
        (setq  GL-result (strcat GL-result "+" num))
        (setq  GL-result (strcat GL-result num))
  (GL-xxjsq)
;清空计算框
(defun GL:key11 ()
  (set_tile "5" "")
  (mode_tile "5" 2)
;清空历史记录
(defun GL:key12 ()
  (if (GL-qrdhk)
   (start_list "9")
   (end_list)
      (setq file (open GL-text "w"))
      (write-line "" file)
      (close file)
  (mode_tile "5" 2)
;提取数字和运算符
(defun GL:GetNumber (ope / en num i regex ss text tn)
  (setq regex (vlax-create-object "Vbscript.RegExp")) ;引用正则表达式控件
  (vlax-put-property regex "IgnoreCase" 0)            ;不忽略大小写
  (vlax-put-property regex "Global" 1)                ;全文匹配,而不是只匹配第一处
  (setq ss (ssget '((0 . "*TEXT,TCH_ELEVATION,DIMENSION"))))    ;只拾取文字、天正标高
  (if ss
  (setq i 0 Num "")
  (repeat (sslength ss)
    (setq en (ssname ss i))
    (setq GL-ed (entget en))
    (if (= "DIMENSION" (cdr (assoc 0 GL-ed))) (setq text (atof (rtos (cdr (assoc 42 GL-ed)) 2 3))) (setq text (cdr (assoc 1 GL-ed)))); 补充标注文字提取
    (vlax-put-property regex "Pattern" "[^0-9\\+\\-\\*\\/\\.\\(\\)]") ;匹配数字和运算符
    (setq text (vlax-invoke-method regex "Replace" text ""))
    (if (/= text "")
      (if (= Num "") ;表达式加括号
        (if (wcmatch text "*`+*,*`-*,*`**,*`/*")
         (setq Num (strcat"(" text ")") TN nil)
         (setq Num text TN nil)
        (setq TN T)
      (if TN ;表达式加括号
          (setq Num (strcat Num ope "(" text ")"))
          (setq Num (strcat Num ope text))
      ;(if (= Num "")(setq Num text TN nil)(setq TN T));表达式不加括号
      ;(if TN (setq Num (strcat Num ope text)));表达式不加括号
    (setq i (1+ i))
  Num
;计算
(defun GL:Galculate (Num)
  (if Num
    (if (setq GL-result (cal (strcat Num "*" "1.0"))) ;*1.0将整数转换为小数,整数只能介于-32768和32767之间
     (setq GL-result (rtos GL-result 2 GL-precision))
        (set-clip-string GL-result) ;向系统剪贴板写入文字
        (setq GL-Num Num)
        (princ (strcat "\n表达式:" Num "=" GL-result "  >>>>计算结果:" GL-result))
      (alert (strcat Num "   表达式语法错误!"))
;向系统剪贴板写入文字
(defun set-clip-string (STR / HTML RESULT)
    (and (= (type STR) 'STR)
  (setq HTML (vlax-create-object "htmlfile"))
  (setq RESULT (vlax-invoke
     (vlax-get (vlax-get HTML 'PARENTWINDOW)
        'CLIPBOARDDATA
     'SETDATA
     "Text"
     STR
  (vlax-release-object HTML)
;插入计算文字
(defun GL:crjswz (GL-result / h la pt sc st ty tzbl)
   (if (setq pt (getpoint "\n请点取插入点:"))
    (if GL-ed
       (setq ty (cdr (assoc 0 GL-ed));字体类型
             st (if (= "DIMENSION" (cdr (assoc 0 GL-ed))) (getvar "TEXTSTYLE") (cdr (assoc 7 GL-ed)));字体样式
             la (cdr (assoc 8 GL-ed));图层
             h (if (= "DIMENSION" (cdr (assoc 0 GL-ed)))  (* (cdr (assoc 40 (tblsearch "DIMSTYLE" (cdr (assoc 3 (entget (cdr (assoc -1 GL-ed)))))))) (cdr (assoc 140 (tblsearch "DIMSTYLE" (cdr (assoc 3 (entget (cdr (assoc -1 GL-ed))))))))) (cdr (assoc 40 GL-ed)));文字高度
             sc (cdr (assoc 47 GL-ed));天正比例
             ;ar (cdr (assoc 41 GL-ed));文字宽高比
             ;co (cdr (assoc 62 GL-ed));颜色
       (if (wcmatch ty "TCH_*")
          (entmake (list
            '(0 . "TEXT")
             (cons 1 GL-result)
             (cons 7 st)
             (cons 8 la)
             (cons 10 pt)
             (cons 40 (* h sc))
             (cons 41 0.8)
          (entmake (list
            '(0 . "TEXT")
             (cons 1 GL-result)
             (cons 7 st)
             (cons 8 la)
             (cons 10 pt)
             (cons 40 h)
             (cons 41 0.8)
   ;(setq h (getvar 'textsize)) ;当前样式文字高度
   (setq tzbl (getvar "HPSCALE") ;天正比例
         h (* tzbl 3)
      (entmake (list
          '(0 . "TEXT")
           (cons 1 GL-result)
           (cons 10 pt)
           (cons 40 h)
;更新历史记录数据,并保存
(defun GL:update (/ file ex)
  (if GL-result
      (setq ex (strcat GL-Num "=" GL-result))
      (setq GL-lst (append (list ex) GL-lst))
   (start_list "9")
   (end_list)
      (setq file (open GL-text "a"))
      (write-line ex file)
      (close file)
;将历史记录上到计算框
(defun GL:update-edit (value reason / a b ex i len)
  (if (= reason 4)
      (setq ex (nth (atoi value) GL-lst)
            len (strlen ex)
            i 1 b ""
      (while (<= i len)
        (setq a (substr ex i 1))
        (if (= a "=")
            (setq i (1+ len))
            (setq b (strcat b a))
        (setq i (1+ i))
      (set_tile "5" b)
      (mode_tile "5" 2)
(defun GL-qrdhk (/ fname fn x dclid lin re YorN)
       (foreach x '(
                     "  qrdhk : dialog{"
                     "  spacer_1;"
                     "      :text{key=\"2\";label=\"是否清除历史记录\";}"
                     "  spacer_1;"
                     "  :row {"
                     "      :button{key=\"1\";label=\"是\";width=8;}"
                     "  spacer_1;"
                     "      cancel_button;"
                     "  spacer_1;"
              (princ x fn)
              (write-line "" fn)
       (close fn)
       (cond
            ((= re 1) (setq YorN T))
       (close fn)
       YorN
发表于 2020-12-9 10:28:38 | 显示全部楼层
我研究了,没成功,你的问题再补充一下,重新打开自动清空,或者按DELETE也可以删掉,也会很方便,最好这两个都优化上
 楼主| 发表于 2020-12-9 10:33:37 | 显示全部楼层
xj6019 发表于 2020-12-9 10:28
我研究了,没成功,你的问题再补充一下,重新打开自动清空,或者按DELETE也可以删掉,也会很方便,最好这两 ...
已经改了,你看一下,是不是那样
发表于 2020-12-10 18:18:07 | 显示全部楼层
顶一下,期待解决
发表于 2021-1-6 07:36:58 | 显示全部楼层
顶一下  顶一下
发表于 2023-7-1 18:32:40 | 显示全部楼层
顶一下,计算的时候很好用。
发表于 2025-1-6 13:11:53 | 显示全部楼层
我按了ESC或者DELETE键,还是没清零。毫米和m不同单位时,能不能自动修改插入的字高
GMT+8, 2025-5-25 15:07 , Processed in 0.203333 second(s), 25 queries , Gzip On.
