查看: 2358|回复: 11
[提问] 做法标注,遇到瓶颈,怎样实现引线无限增加间距
发表于 2020-12-13 20:50:13 | 显示全部楼层 |阅读模式
论坛里一直找做法标注,但不是我想要的,于是自己做一个,苦于半瓶水,不能实现无线间距增加,第二行就重叠了,求助
(defun c:test ()
                (setvar "ORTHOMODE" 1)
                (setq n2 (getvar "DIMSCALE"))
                (setq pt1 (getpoint "\n指定做法层第一点:"))
                (setq pt3 (getpoint pt1 "\n指定做法标注点:"))
                (setq pt4 (getpoint pt3 "\n指定标注方向点:"))
                (setq BNO (getstring  "\n输入做法"))
                (command ".qleader" pt1 pt3 pt4 "" BNO nil)
                (while (setq pt2 (getpoint pt1 "\n指定做法层下一点:<退出>:"))
                         (vl-cmdf pt2 "")
                         (setq pt1 pt2)
                         (setq kang (angle pt1 pt3))
                         (setq len1 (* 5 n2));间距1
                         (setq len2 (* 5 n2));间距2
                         (setq p3 (polar pt3 kang len1));
                         (setq p4 (polar pt4 kang len2))
                          (command ".qleader" pt1 p3 p4 "" "" nil)
               (vl-cmdf "")
再次循环就出现重叠了
实现如图样子
程序目前执行后这样子
贴个图会更清楚  发表于 2020-12-14 20:17
 楼主| 发表于 2020-12-14 21:07:13 | 显示全部楼层
用笨办法实现了5层标注,因为大多情况下也就差不多5层
(defun c:test4 ()
         ;(progn
              ;  (QleaderSet)
        (if (= pt1 nil)
            (setq pt1 (getpoint "\n*错误*,指定做法层第一点:或按ESC键结束命令:"))
                (if (= pt2 nil)
                      (setq ptx (getpoint pt1 "\n指定做法标注点:"))
                      (setq pty (getpoint ptx "\n指定标注方向点:"))
                          (setq pt3 (getpoint pt2 "\n指定做法层下一点:<退出>:"))
                          (if (= pt3 nil)
                               (setq BNO1 (getstring  "\n输入做法一:"))
                               (setq BNO2 (getstring  "\n输入做法二:"))
                               (setq kang (angle pt1 ptx));角度
                               (setq p1 (polar ptx kang len1));
                   (setq p2 (polar pty kang len1))
                               (command ".qleader" pt1 ptx pty "" BNO1 nil)
                               (command ".qleader" pt2 p1 p2 "" BNO2 nil)
                                  (setq pt4 (getpoint pt2 "\n指定做法层下一点:<退出>:"))
                                  (if (= pt4 nil)
                                                (setq BNO3 (getstring  "\n输入做法三:"))
                                                (setq len2 (* 10 n2));间距
                                                (setq p3 (polar ptx kang len2));
                        (setq p4 (polar pty kang len2))
                                                (command ".qleader" pt3 p3 p4 "" BNO3 nil)
                                           (setq pt5 (getpoint pt2 "\n指定做法层下一点:<退出>:"))
                                           (if (= pt5 nil)
                                                          (setq BNO4 (getstring  "\n输入做法四:"))
                                                          (setq len3 (* 15 n2));间距
                                                          (setq p5 (polar ptx kang len3))
                                                          (setq p6 (polar pty kang len3))
                                                          (command ".qleader" pt4 p5 p6 "" BNO4 nil)
                                                          (setq BNO5 (getstring  "\n输入做法五:"))
                                                          (setq len4 (* 20 n2));间距
                                                          (setq p7 (polar ptx kang len4))
                                                          (setq p8 (polar pty kang len4))
                                                          (command ".qleader" pt5 p7 p8 "" BNO4 nil)
发表于 2020-12-15 00:25:56 | 显示全部楼层
  1. (defun c:tt ()
  2.   (setq n2 (getvar "DIMSCALE"))
  3.   (setq pt1 (getpoint "\n指定做法层第一点: "))
  4.   (setq pt3 (getpoint pt1 "\n指定做法标注点: "))
  5.   (setq pt4 (getpoint pt3 "\n指定标注方向点: "))
  6.   (setq BNO (getstring "\n输入做法: "))
  7.   (setq rad (angle pt3 pt1))
  8.   (setq len (* 5 n2))
  9.   (setvar "osmode" 0)
  10.   (command "qleader" pt1 pt3 pt4 "" BNO nil)
  11.   (while (setq pt2 (getpoint pt1 "\n指定做法层下一点<退出>: "))
  12.     (setq tx (getstring "\n输入做法: "))
  13.     (setq pt1 pt2)
  14.     (setq pt3 (polar pt3 rad len))
  15.     (setq pt4 (polar pt4 rad len))
  16.     (command ".qleader" pt1 pt3 pt4 "" tx nil)
  17.   )
  18.   (princ)
  19. )
发表于 2020-12-15 00:35:23 | 显示全部楼层
  1. (defun c:tt () ;tt(做法标注) 全自动方式
  2.   (setq lst '("A" "B" "C" "D" "E")) ;做法表
  3.   (setq n2 (getvar "DIMSCALE"))
  4.   (setvar "orthomode" 1)
  5.   (setq pt1 (getpoint "\n指定做法层第一点: "))
  6.   (setq pt3 (getpoint pt1 "\n指定做法标注点: "))
  7.   (setq pt4 (getpoint pt3 "\n指定标注方向点: "))
  8.   (setq rad (angle pt3 pt1))
  9.   (setq len (* 5 n2))
  10.   (setvar "osmode" 0)
  11.   (command "qleader" pt1 pt3 pt4 "" (car lst) nil)
  12.   (setq lst (cdr lst))
  13.   (foreach tx lst
  17.   )
  18.   (princ)
  19. )
代码怎么使用呢?  发表于 2020-12-18 15:12
 楼主| 发表于 2020-12-15 07:23:20 | 显示全部楼层
非常感谢,这两个都很好,第二个可以做成对话框,适用于5个内的做法,后面再加工一下,会更加适合我使用
几个都无所谓  发表于 2020-12-15 09:16
发表于 2020-12-18 15:12:26 | 显示全部楼层
代码怎么用啊?
发表于 2021-1-9 22:37:52 来自手机 | 显示全部楼层
学习中,这个功能不错。
发表于 2023-9-22 16:39:17 | 显示全部楼层
学习中,这个功能不错。
GMT+8, 2025-5-23 23:57 , Processed in 0.883671 second(s), 26 queries , Gzip On.
