查看: 2334|回复: 15
[源码] 字体分类更换
发表于 2020-12-23 14:36:40 | 显示全部楼层 |阅读模式
修改好的源码在11楼。
 楼主| 发表于 2020-12-24 12:47:14 | 显示全部楼层
bssurvey 发表于 2020-12-24 10:58
我在2008測試是沒問題的
朋友,你是对的,确实是字体的问题,是在定义变量时少写了一个字母,导致出错。修改后放在这里,供有需要的朋友自取。
两种方法,效果一致。
(defun c:11E (/ date1 date2 font font_obj fontlist fontname n to-shx to-ttf)
        (setq date1 (getvar "millisecs"))
        (defun to-shx(shxx shxb / a3)
                (setq a3 (entget (tblobjname "style" font)));取出字体的数据串行
                (setq a3 (subst (cons 3 shxx )(assoc 3 a3) a3));将字体字型改成新字型
                (setq a3 (subst (cons 4 shxb )(assoc 4 a3) a3));将字体字型改成新字型
                (entmod a3);更新字体
        (defun to-ttf(ttf / obj)
                (setq obj (vla-add font_obj font))
                (vla-setFont obj ttf :vlax-false :vlax-false 134 2)
        (setq font_obj (vla-get-TextStyles(vla-get-ActiveDocument(vlax-get-acad-object))))
        (vlax-for sobj font_obj
                (setq fontname (vla-get-name sobj))
                (setq fontlist (vl-remove "" (cons fontname fontlist)))
        (setq n 0)
        (repeat (length fontlist)
                (setq font (nth n fontlist))
                (cond
                        ((wcmatch font "*仿宋*")(to-ttf "仿宋"))
                        ((wcmatch font "*宋体*")(to-ttf "宋体"))
                        ((wcmatch font "*黑体*")(to-ttf "黑体"))
                        (t(to-shx "tssdeng.shx" "hztxt.shx"))
                (setq n (+ n 1))
        (repeat 1 (vl-cmdf "regen"))
        (setq date2 (getvar "millisecs"))
        (princ (strcat ",耗时" (rtos(/(- date2 date1)1000.000)2 3) "秒。"))
(defun C:22E(/ a1 a2 date1 date2 to-shx to-ttf)
                (setq a3 (entget (tblobjname "style" a2)));取出字体的数据串行
                (entmod a3);更新字体
        (defun to-ttf(ttf / font_obj obj)
                (setq obj (vla-add font_obj a2))
        (setq a1 (tblnext "style" t));将指针移到第一个字体
        (while a1
                (setq a2 (cdr (assoc 2 a1)));取出字体名称
                (cond
                        ((wcmatch a2 "*仿宋*")(to-ttf "仿宋"))
                        ((wcmatch a2 "*宋体*")(to-ttf "宋体"))
                        ((wcmatch a2 "*黑体*")(to-ttf "黑体"))
                (setq a1 (tblnext "style"));找出下一个字体
发表于 2020-12-23 15:10:02 | 显示全部楼层
試看看 是不是這樣,大家一起學習
(defun c:tty (/ font font_obj fontlist fontname n toshx tottf)
  (defun toshx(shx shxb / a3)
    (setq a3 (entget (tblobjname "style" "font")));取出字体的数据串行
    (setq a3 (subst (cons 3 "shxx" )(assoc 3 a3) a3));将字体字型改成新字型
    (setq a3 (subst (cons 4 "shxb" )(assoc 4 a3) a3));将字体字型改成新字型
    (entmod a3);更新字体
  (defun tottf(ttf / obj)
  (setq n 0)
    (cond
      ((= font "*黑体*")(tottf "黑体"))
      ((= font "*仿宋*")(tottf "仿宋"))
      ((= font "*宋体*")(tottf "宋体"))
      (t(toshx "tssdeng.shx" "hztxt.shx"))
    (setq n (+ n 1))
发表于 2020-12-24 10:31:07 | 显示全部楼层
nyistjz 发表于 2020-12-24 09:58
你还没有看懂这个程序的运行顺序,是从第12行开始的。
真的很抱歉
看看是不是這樣
  (defun toshx(shxx shxb / a3)
    (setq a3 (subst (cons 3 shxx)(assoc 3 a3) a3));将字体字型改成新字型
    (entmod a3);更新字体                 ; 增加这一行就可以了
    (setq a3 (subst (cons 4 shxb)(assoc 4 a3) a3));将字体字型改成新字型
    (entmod a3);更新字体
  (setq n 0)
    (cond
      ((wcmatch font "*黑体*")(tottf "黑体"))
      ((wcmatch font "*仿宋*")(tottf "仿宋"))
      ((wcmatch font "*宋体*")(tottf "宋体"))
    (setq n (+ n 1))
 楼主| 发表于 2020-12-23 15:17:33 | 显示全部楼层
bssurvey 发表于 2020-12-23 15:10
試看看 是不是這樣,大家一起學習
(defun c:tty (/ font font_obj fontlist fontname n toshx tottf)      ...
你测试一下,好像是不行的。
发表于 2020-12-23 15:27:09 | 显示全部楼层
nyistjz 发表于 2020-12-23 15:17
你测试一下,好像是不行的。
(tblobjname "style" "font") font 要圖檔有的字型名稱, 例如"Standard"
 楼主| 发表于 2020-12-23 15:32:56 | 显示全部楼层
bssurvey 发表于 2020-12-23 15:27
(tblobjname "style" "font") font 要圖檔有的字型名稱, 例如"Standard" 好像沒用到(defun tottf(ttf / ...
有这个定义!
发表于 2020-12-23 17:26:56 | 显示全部楼层
有这个定义!
(setq a3 (subst (cons 3 shxx )(assoc 3 a3) a3));将字体字型改成新字型  應該是shxx 並沒有設定變數,是哪一個新字型,所以才會出錯
    (setq a3 (subst (cons 4 shxb )(assoc 4 a3) a3));将字体字型改成新字型 這個shxb 也是一樣
 楼主| 发表于 2020-12-24 09:58:35 | 显示全部楼层
bssurvey 发表于 2020-12-23 17:26
(setq a3 (subst (cons 3 shxx )(assoc 3 a3) a3));将字体字型改成新字型  應該是shxx 並沒有設定變數, ...
 楼主| 发表于 2020-12-24 10:49:34 | 显示全部楼层
bssurvey 发表于 2020-12-24 10:31
真的很抱歉
看看是不是這樣
谢谢您,还是不对,您自己在电脑上试一下,看能不能运行。
我怀疑(entmod a3)解析出来的a3格式不对,所以entmod运行不了。
发表于 2020-12-24 10:58:19 | 显示全部楼层
我怀疑(entmod a3)解析出来的a3格式不对,所 ...
我在2008測試是沒問題的
GMT+8, 2025-9-16 22:08 , Processed in 0.194221 second(s), 28 queries , Gzip On.
