 - ;;Entmake 符号表的必要条件
- (defun C:w4 (/ DATA FLN FLO I L1 LST NEWNAME OLDNAME YAO)
- (cond ((and (setq FLN (getfiled "輸出的LISP文件:" "" "LSP" 1))
- (setq FLO (open FLN "w"))
- (setq lst '("Layer" "Ltype" "View" "Style" "Appid" "Ucs" "Dimstyle" "Vport"))
- (setq L1 '("AcDbLayerTableRecord" "AcDbLinetypeTableRecord"
- "AcDbViewTableRecord" "AcDbTextStyleTableRecord"
- "AcDbRegAppTableRecord" "AcDbUCSTableRecord"
- "AcDbDimStyleTableRecord" "AcDbViewportTableRecord"
- (foreach n lst
- (setq yao nil)
- (setq data (TBLNEXT n T))
- (setq yao (cons (car data) yao))
- (setq data (cdr data))
- (setq yao (cons '(100 . "AcDbSymbolTableRecord") yao))
- (setq yao (cons (cons 100 (car L1)) yao))
- (setq L1 (cdr L1))
- (foreach X data (setq yao (cons x yao)))
- (setq yao (REVERSE yao))
- (setq i 0)
- (setq lst nil)
- (setq oldName (cdr (assoc 2 yao)))
- (foreach X yao
- (setq i (1+ i))
- (setq NewName (strcat oldname (VL-PRINC-TO-STRING i)))
- (setq data (subst (cons 2 NewName) (assoc 2 yao) yao))
- (cond ((not (entmakeX (vl-remove X data))) (setq lst (cons X lst))))
- (setq lst (reverse lst))
- (write-line (strcat "(EntMakeX '" (vl-prin1-to-string lst) ")") FLO)
- (close FLO)
- (princ)
结果:
;;符号表的必要条件
(EntMakeX '((0 . "LAYER")
(100 . "AcDbLayerTableRecord")
(2 . "MyLAYER")
(70 . 0)
(EntMakeX '((0 . "LTYPE")
(100 . "AcDbLinetypeTableRecord")
(2 . "MyLTYPE")
(70 . 0)
(EntMakeX '((0 . "VIEW")
(100 . "AcDbViewTableRecord")
(2 . "MyVIEW")
(70 . 0)
(EntMakeX '((0 . "STYLE")
(100 . "AcDbTextStyleTableRecord")
(2 . "MySTYLE")
(70 . 0)
(EntMakeX '((0 . "APPID")
(100 . "AcDbRegAppTableRecord")
(2 . "MyAPPID")
(70 . 0)
(EntMakeX '((0 . "UCS")
(100 . "AcDbUCSTableRecord")
(2 . "MyUCS")
(70 . 0)
(11 0.904145 0.427225 0.0)
(12 -0.427225 0.904145 0.0)
(EntMakeX '((0 . "DIMSTYLE")
(100 . "AcDbDimStyleTableRecord")
(2 . "My")
(70 . 0)
(EntMakeX '((0 . "VPORT")
(100 . "AcDbViewportTableRecord")
(2 . "My")
(70 . 0)
