查看: 727|回复: 2
[提问] 求改一代码,不清楚规则很抱歉
发表于 2021-1-20 09:00:56 | 显示全部楼层 |阅读模式
2明经币
  • 求改一代码,分图后不删原图,感激。
  • 原贴
  • http://bbs.mjtd.com/forum.php?mod=viewthread&tid=108136&highlight=%B7%D6%CD%BC
  • ;;分图
  • ;;假如一个文件内画许多图,用电脑的搜索功能可能找不到,需拆分,以文件名保存,但于后来找查
  • (defun C:ft (/ ANSWER EN FLAG FLAG1 INITDIR NEWDNAME SS)
  •   (if (setq Initdir (getvar "dwgprefix"))
  •     nil
  •     (progn (princ "\n 文件未保存,不能分图") (exit))
  •   (setq flag1 T)
  •   (while (and flag1
  •         (setq en (entsel "\n >拾取文件名 "))
  •         (setq en (nentselp (cadr en)))
  •         (setq NewDName (cdr (assoc 1 (entget (car en)))))
  •         (equal (type NewDName) 'STR)
  •     (if  (findfile (strcat Initdir NewDName ".DWG"))
  •       (setq flag T)
  •     (while flag
  •       (princ
  •   (strcat "\n 文件名" NewDName "已经存在,请重输入文件名")
  •       (setq NewDName (getstring "\n???输入文件名: "))
  •   nil
  •   (setq flag nil)
  •     (princ "\n >>此图范围")
  •     (setvar "NOMUTT" 1)
  •     (setq ss (ssget))
  •     (setvar "NOMUTT" 0)
  •     (command "_.WBLOCK"
  •        (strcat Initdir NewDName)
  •        "0,0"
  •        ss
  •     (princ (strcat "\n >>>文件" NewDName "成功保存!!!\n"))
  •     (if  (ssget "X")
  •       (progn
  •   (initget "Yes No")
  •   (setq answer (GETKWORD "[停止(N)/断续(Y)]<断续Y>"))
  •   (if (equal answer "No")
  •     (setq flag1 nil)
  •       (setq flag1 nil)
  •   (princ)
最佳答案
查看完整内容
(command "undo" "be") ;可以在此加入這一行 (command "_.WBLOCK" (strcat Initdir NewDName) "" "0,0" ss "" ) (princ (strcat "\n >>>文件" NewDName "成功保存!!!\n")) (command "undo" "b") ;在此加入這一行
发表于 2021-1-20 09:00:57 | 显示全部楼层
       (command "_.WBLOCK"
       "0,0"
       ss
 楼主| 发表于 2021-1-21 11:31:12 | 显示全部楼层
       (command "_.WBLOCK"
       (strcat Initdi ...
很感谢,
GMT+8, 2025-5-17 07:08 , Processed in 0.171527 second(s), 26 queries , Gzip On.
